Sun Apr 28, 2013Total posts : 11
SCK
SCK
Topic: Electrical Fitting and Cable Wiring
when the ceiling fan conduit pipe for ceiling fans should be put up (like hooks for fans), before putting the RCC slab along with rod mesh or after the RCC slab is put
The comment above talks about the article   "Electrical Fitting and Cable Wiring "
Mon Apr 29, 2013Post  #1
Dear Sck
         I do not under stand your language but for fixing fan hook the procedure is that
  1 Lay the shuttering plates.
2. bind the ms steel bars as per design.
3. Lay the conduit pipes on steel bars and also lay the fan hook box connected with the conduit pipe.
4. Lay the concrete in slab.
Mon Apr 29, 2013Post  #2
SCK
SCK
Post subject: construction of 1st floor
Dear sir,
Meanwhile, I called the electrician, he also informed me same facts that at the time of shuttering, he will come and fix the fan boxes with conduit pipes in all the rooms wherever fans are required. Now I am in the process of selecting a shuttering wala who will do the shuttering along with `Latak` beams. Than a mistry who can put the JAAL of 12 mm bars with  6 x 6 spacing.
 I intend to have some flat hidden beam in slab wherever span is more than 10 ft (like 14 or 18 ft) . Whether this flat hidden beams (4x7) should be of 12 mm or 16 mm bars, I am mulling over the issue.
Than I intend to engage a ready mix manufacturer who can provide me M 20 grade concrete with pump etc.
Thanks for your comments /suggestions. Please let me know, whether these services are provided by Gharexpert.com
regards,
SCK
Mon Apr 29, 2013Post  #3
Dear Sck
       use 6 nos16 mm dia bars in beam. Gharexpert do not arrange labor or materials.
Mon Apr 29, 2013Post  #4
SCK
SCK
Thanks, now when I am using 16 mm bars for flat hidden beam to reduce the span, can I use 12mm & 10 mm bars for  6 x 6 Jaal. I hope it won't compromise the structure strength. I can increase concrete grade from M 20 to M 25. I hope the weight per cu meter of M 20 & M 25 are approximately same. I understand 1 cu m of M 25 concrete weighs 2550 kg.
Tue Apr 30, 2013Post  #5
Dear Sck
        Use 12mm bars as main steel and 10 mm bars as distribution steel. Use M20 orM25 IS UP TO YOU.
Tue May 07, 2013Post  #6
SCK
SCK
How much RM (I intend 14 cu m) should be ordered to the firm for 5 inch thickness of RCC slab for area of 950 sq ft plus Latak beam of 1 ft, with 200 ft length. They want 100 % advance. Is it industry practice to take 100 % advance before supplying the RM
regards,
SCK
Tue May 07, 2013Post  #7
Dear SCK
          !5 cum concrete mix is required for laying RCC slab and beam. As per advance, it is the business practice, you will deal with them.
Mon Apr 14, 2014Post  #8
sk6517
sk6517
Post subject: Electrical Fitting and Cable Wiring
My builder is recently using cable wire of rr/kebel company and it is of ISI mark.Is there any idea of this campany cable?Is there anyone who can suggest better cable for internal concealed wiring ?
Mon Feb 16, 2015Post  #9
Vijay Mishra
Vijay Mishra
Mon Feb 16, 2015Post  #10
Vijay Mishra
Vijay Mishra
Dear SL Gupta Ji, I am constructing a new house, conduiting for electrical cables are laid I need your help to answer mentioned queries:- 1) How much "mm" cable should be laid for normal (5-10 AMP) connections & power (10-20 AMP) connections, what's their exact specification. 2)Which brand is best - Finolex, RR Kabel, polycab? 3) At what stage should i involve laying of necessary cabling for AC (split). Kindly advise. Regards Vijay
Mon Feb 16, 2015Post  #11
Vijay Mishra
Vijay Mishra
electrical installation
Last answer on 11/27/2021 2:32:14 AM. by Navneet Jharia. Forum started by brajesh pandey
1992
cables
Last answer on 7/3/2020 10:07:56 PM. by JAI PRAKASH. Forum started by ARVIND GOYAL
2962
18382
1906
1960
2466
2022
865
How do I choose a good IPTV provider to replace my cable TV?
Last answer on 1/5/2022 12:35:15 AM. by SusanBones. Forum started by Kaliopsy
478
Hi everyone, what do you think is the best cable TV operator?
Last answer on 2/20/2022 3:59:23 PM. Forum started by Erling
2507
1921
electrical work in house
Last answer on 9/4/2021 6:00:39 AM. by JAI PRAKASH. Forum started by milind
2274
Ac and Electrcial
2186
2303
Electrical Wiring
Last answer on 5/16/2013 12:22:40 PM. by S L Gupta (Civil Engg). Forum started by Unnikrishnan
1511
Electrical wiring
Last answer on 11/1/2015 6:41:12 PM. by JAI PRAKASH. Forum started by ani
2430
Electic wires
Last answer on 1/17/2014 12:15:51 PM. by S L Gupta (Civil Engg). Forum started by rajesh
4315
i am fitting ac in new home what mm size of wire i should use for electrical sup
Last answer on 9/21/2020 3:10:48 AM. by JAI PRAKASH. Forum started by ashok
1342
Last answer on 3/4/2015 1:22:04 PM. by S L Gupta (Civil Engg). Forum started by jay prakash
Electrical
Earthing
Electric
Electric Shock Proof Home
Electric
What is binding wire
Switches
Switches and Sockets
Electric
