Electrical Piping during slab and mould construction
Fri Apr 15, 2016Total posts : 1
tejaswi
tejaswi
Topic: Electrical Piping during slab and mould construction
Hi All,
I am under construction of a g+2 duplex home (27x40)in bangalore, I have a question about howmany electrical pies we need to put vertically in the mould so that its sufficiet. I have seen some building having upto 9  1inch  pipes but my electrician has put only 4  (3/4 inch pipes). does it have any issue. When asked he says it should not have any problem.
please advice
Sat Apr 16, 2016Post  #1
Dear Tejaswi
           The pipes are required according to point so  your electrician lay pipes according to the need.
3753
1525
2275
Ac and Electrcial
2850
What are requirements of drainage and sanitation for dwelling area covered with individual?
Last answer on 6/20/2013 5:14:02 PM. by Sandip Kar. Forum started by g.s.rajan
4807
2593
JOINERY WORKS
2127
Related to Sunken Slab
2300
1965
2843
Last answer on 6/17/2013 5:17:52 PM. by Navneet Jharia. Forum started by g.s.rajan
1727
Hello i am going to install electrical pipe line for the house, i need your help
Last answer on 2/14/2013 11:16:40 AM. by S L Gupta (Civil Engg). Forum started by Pradyumna Lal Pradhan
1986
Water Curing
Last answer on 9/12/2014 9:52:07 PM. by JAI PRAKASH. Forum started by awdhesh
2231
sewage pipes
1762
We are about the start the 1st floor slab of our bungalow. However, we are hesi
Last answer on 6/11/2011 4:08:47 PM. by S L Gupta (Civil Engg). Forum started by blossom
2557
17
General
Electric
Various Types of Bricks
