| General Guidelines While Designing Water Supply Pipe Lines Designing pipe lines in a house or building needs careful vision. There is no cross connection between pipes for drink.. |
| Energy Saving Tips Saving energy will definitely help you minimize your energy/electricity bills. Here are some nice tips to save energy;.. |
| Energy Saving Fans Everyday rising energy demands reminds us to explore new energy saving devices. Energy saving ceiling fans is such a d.. |
| Electricity Consumption of Various Appliances Saving electricity not only adds to your money but will help thousands in demand of energy also.It’s duty of every cit.. |
| Demarcation/layout Procedure Baseline is marked on the ground either from centre line of the road or from any permanent building nearby |
| Electric Fitting and Lighting Fixtures Electric fitting must be safe and ensure proper safety to the occupants of the house. Low quality products or applianc.. |
| Types of Valves Used In Water Supply Pipe Lines Valves in pipe lines are provided to control supply of water. They are used to stop supply when any repair is carried .. |
| Purchasing Guidelines for Sanitary material and Precautions While Laying Sewer Pipes line Cast iron pipe is generally used in sewer lines. The points should be kept in view while purchasing CI pipes. |
What are various types of valves for water pipe lines? Valve is suitable means of connections for inserting and controlling the flow of the water.Nominal size of stop valve .. |
