Drawing Room
Entrance main door location for east facing house is correct? please look the attached image
Wed Aug 06, 2014
senthil
Topic: Entrance main door location for east facing house is correct? please look the attached image
I have attached the building plan. I want to know that the main door location in the house plan is Ok as per vastu. Please suggest the correct location of main door as per vaastu.
Senthil Kumar
Untitled.jpg on Wed Aug 06, 2014,&n
Sat Aug 09, 2014
Post subject: vastu for main door
Hello Sir,
The main entrance should be in the East or in the North direction. It should not be in front of the compound wall. Avoid the main door directly facing the main door of the opposite house.Its width should be bigger than other doors of the house.
If still you have any doubt please consult a vastu expert.
Thanks.
2424
WHICH IS CORRECT LOCATION FOR MAIN DOOR
Last answer on 11/18/2013 4:15:10 PM. by
jjanmenjay
2496
images of iron gate attached to main door
Last answer on 11/18/2013 4:05:44 PM. by
nagaraja k.n.
2622
Vastu of the attached flat
Last answer on 11/14/2016 11:06:33 AM. by
Megasonali
2678
please give images for iron door in front of main wooden door,
Last answer on 11/18/2013 3:27:52 PM. by
nagaraja k.n.
14026
Is this good house -Vastu
Last answer on 8/24/2021 1:35:52 AM. by
sathiyamoorthi
Mvs Rao
2531
i want modren designs of main door frames.please sent the images to prashanthkum
Last answer on 11/18/2013 4:12:52 PM. by
kiranmai.a
East face house main door exact opposite neem tree there is it good or bad
Last answer on 7/3/2020 11:47:46 PM. by
K.Raj Kumar
2496
Which is best location for main door in east facing plot as per the purvashadha
Last answer on 1/2/2021 5:22:27 AM. by
Srinath
3406
Dexter
plabita
2447
Last answer on 1/27/2015 7:35:32 PM. by
Murali
2287
my friends flat has east aagney main entrance door.please give the remedy for th
Last answer on 12/4/2013 2:47:20 PM. by
iangaswamy
1252
Last answer on 6/12/2018 1:25:38 AM. by
Kiran kabadi Kabadi
5822
Gunja
2286
Suggest about diagonal plots facing ES facing, with main gate at east end and m
Last answer on 3/13/2012 1:14:13 AM. Forum started by
Major Anil Kumar
2104
Bathroom door facing main entrance door in flat .can it be any problem?
Last answer on 7/16/2014 10:41:41 AM. by
ANURAG DUBEY
1845
Muneeruddin Syed
4026
what problems occur if the main door is in south east corner that is agnayem but
Last answer on 8/3/2010 11:05:14 AM. by
ashu jain
ddsureshd
2072
MAIN DOOR[ENTRANCE]
Last answer on 4/28/2016 9:46:52 AM. by
Shivaraj
Shivaraj
2219
Last answer on 2/4/2015 2:01:32 PM. by
MUNNAWAR
3676
rockklause
anil kumar
3086
mahambaloch
Rohit Patel
2316
vrameshkumar
3406
Dexter
plabita
2265
Anuj Anand
5121
Rinder76
Juliet
1845
Muneeruddin Syed
7104
mohan
2554
Roy
2143
gangula
1723
Hari Krishnan
1821
Ankur
1833
Rahul Bhandari
2073
CalvinWolfe
Priya
5822
Gunja
2676
pritianuj
7305
manisha
kirit
7537
jayant jaiswal
2704
Hari Krishnan
Right size cupola
Bathroom Pictures
How to Design a Garage
