Epoxy painting for floors
Sat Apr 04, 2015Total posts : 1
Akshay Wadke
Akshay Wadke
Topic: Epoxy painting for floors
What would be the cost for epoxy painting of floors for clean room. Considering it is light load movement (troley not above 50kg), would 2-3 coats be sufficient. Is it better to insist on spray painting method rather than the traditional coating method? Thanks.
Sat Apr 04, 2015Post  #1
Dear Akshay
       In my view spray painting is better option.For cost contact any professional for estimating.
Do you have paint reps in the USAaround the northwest Indiana area.I have a cust
Last answer on 11/16/2012 8:35:46 PM. Forum started by Jackie Martin
2448
what is epoxy floor coating? please explain me.
Last answer on 2/25/2022 7:32:12 AM. by Jemimmarichardson. Forum started by RRSAMY
paint
Last answer on 6/30/2021 1:46:52 AM. by S L Gupta (Civil Engg). Forum started by jollyjodhaka
2370
epoxy flooring
Last answer on 4/25/2011 10:23:24 PM. by Nikita. Forum started by sonia
2306
Epoxy Flooring
Last answer on 5/8/2011 7:41:36 PM. by Farooq Akmal Butt. Forum started by Moreshwar Kelkar
2720
2967
Tips for Cement Paint
3166
4565
PAINTING
Last answer on 2/24/2022 12:54:30 PM. by Girish. Forum started by Girish
4504
Wall Putty ,primer and paint
1522
concrete floors
1798
Last answer on 8/29/2016 12:10:36 PM. by S L Gupta (Civil Engg). Forum started by vishal
3074
4041
Paint vs Wallpaper
2544
need paint in my house so wants to see a demo of drawing room how it look after
Last answer on 7/3/2020 10:09:31 PM. Forum started by muddassir
2295
Washable Paints good or bad
Last answer on 11/20/2011 11:49:18 AM. by Amit Hasija. Forum started by raghuam
1869
Leakages in Apartment
Last answer on 12/12/2015 12:58:49 AM. by JAI PRAKASH. Forum started by nitin_patel
3069
Painting
1125
Is Fusion-Based Epoxy coating a practical means to prevent corrosion in TMT ste
Last answer on 1/10/2019 12:19:14 AM. Forum started by Anu Mohan
15
17
Epoxy
Epoxy Flooring
Epoxy flooring can be defined as several layers of any type of epoxy resin that is applied on a floor surface. This ty..
Terrazzo
Painting Study Room
A stimulating and cool color is very energizing for the place where one begins the way to go through the career. Let’s..
Paint
Paint Colors for Living room
This article gives you advice regarding paint colors for your living room. Colors protect, decorate surfaces and give ..
Beyond
Surface
Tips for Synthetic Enamel Paint
Synthetic enamel paint is an oil based paint which is applied to provide better griping and long lasting finish. It is..
Tips for Dry Distemper Paint
Dry distemper is water based wall paint and is more durable than color wash. It contains a glue and tinted powdered ch..
Plastic emulsion paint is a water based paint which gives soft effect to the walls. It is long lasting, washable and e..
Wall
Wall painting design
