Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> Estimate for 3rd and 4th floor
Thu Nov 17, 2016Total posts : 0
Shubhank Gaur
Shubhank Gaur
Topic: Estimate for 3rd and 4th floor
I need a rough estimate for construction of 3rd and 4th floor of my home in Ghaziabad area. A rough estimate figure would do, would appreciate any kind of detailing in it. I just want a general idea to cross match with what contractors here are quoting.
I have 1600sqft area and have proper and strong foundation along with Ground and 1st floor.
I am not looking to create rooms on my 3rd and 4th floor for now and would just like to leave them as "halls".
As such, I am looking to have around 9 pillars, 4 walls and 1 roof/rcc slab/lanter on each floor (I need 2 floors so per floor cost would be perfect).
Any estimate idea of labor charge will be appreciated as well, since the same contractor who did our G+1 is quoting more labor charges now justifying them as "the higher you construct, the more labor it costs".
1335
I HAVE 13*60PLOT ...WANT ABASEMENT&4BHK UPTO 3RD FLOOR
Last answer on 1/4/2017 11:57:30 AM. by S L Gupta (Civil Engg). Forum started by PANKAJ
1837
my flat is on 3rd floor and is SW facingpl advise necessary corrective measures.
Last answer on 12/12/2011 7:39:57 AM. Forum started by poornima
3947
need for plan
4984
Marriage hall
Last answer on 7/3/2020 11:49:25 PM. by JAI PRAKASH. Forum started by PRAVINKUMAR.T
5267
I am planning to built a marriage hall in 7500 sqft open space in coimbatore . 1
Last answer on 10/14/2021 9:24:37 AM. by Alexander Graf. Forum started by PRAVINKUMAR.T
1613
My rasi is mesham star is krithika, is south west facing door in the 3rd floor
Last answer on 7/31/2017 11:58:32 PM. by S L Gupta (Civil Engg). Forum started by karthikkan
1699
SIR, I WANT TO CONSTRUCT MY HOUSE 3RD FLOOR. TODAY THER IS G 2FLOOR.I WANT EXTEN
Last answer on 3/5/2016 9:50:33 PM. by JAI PRAKASH. Forum started by cvsatav
1942
Construction cost
Last answer on 4/8/2014 4:11:47 PM. by awdhesh. Forum started by awdhesh
3128
1495
Map for house construction from foundation to 3rd floor need house plan
Last answer on 11/28/2016 1:23:47 PM. by S L Gupta (Civil Engg). Forum started by anuradha
Estimation for ground + 2 floor
Last answer on 2/23/2015 10:36:37 PM. Forum started by sboloor
1420
Last answer on 9/28/2018 11:39:45 PM. by S L Gupta (Civil Engg). Forum started by Anand jaiswal
gate & job
Last answer on 4/2/2015 1:57:25 AM. Forum started by minhaj sk
1649
Design Layout for Shops and Flats
Last answer on 5/10/2016 11:43:26 AM. by S L Gupta (Civil Engg). Forum started by Amir Rehman
2032
in vasthu how to find members of a familywhere r the 1st 2nd 3rd...like that chi
Last answer on 3/28/2011 8:28:05 PM. by Swati Sharma. Forum started by D.Ramachandran
2350
Check the load
Last answer on 11/17/2013 12:35:51 AM. by Dilip. Forum started by Dilip
2388
7980
How many pillars needed
Last answer on 7/17/2013 12:06:57 PM. by S L Gupta (Civil Engg). Forum started by DK
2625
Layout and plans
Last answer on 2/5/2013 11:59:30 AM. by Anupam Anurag. Forum started by deepak
5811
3792
9884
2670
4627
4143
2865
5006
3655
1864
2800
2610
2372
2462
2638
1807
3607
6254
Terrazzo
Refinishing Hardwood Floors
Checklists for flooring
Comparison
Appropriate
Linoleum
Linoleum Flooring
Linoleum flooring is a popular choice when you are looking for style and ease at the budget. You can choose any color ..
Choose
Choose Flooring for your Kitchen
Kitchen flooring should be fit into the kitchen design in such a way that will work according to your personal needs a..
Oak
Oak Flooring
A beautiful, elegant and sophisticated option of flooring adds to the value of your home. Oak flooring is such a choic..
Drawing
Drawing Room Flooring
