Raw Material
Fri Aug 08, 2014
Mohan Bhagwat
Topic: Estimation of quantities of raw materials for sungle to 4 storyed Buildings
CBRI Roorkee in the year 1972 , April had published a Bulletin which helps to estimate fairly accurate quantum of various raw materials required in construction of buildings with single to 4 storyed house and plinth areas upto 100 sq m. CBRI had considered the actual Bill of Quantities procured from builders then.
I f any thumb rule or empirical formula is there to estimate such quantities for multi storyed apartments it shall be very helpful for me in calculating environmental impacts for ever growing demand for housing projects.
Requested for help from experts.
Thu Aug 14, 2014
Dear Mohan
There are many books or material for detail of quantity of construction items, these also printed in states PWD OR CPWD SHEDULE OF RATES.Some are as under
1. c.conc.1:8:16 for 1cum= cement= 1.8 bags, sand .5 cum, brick or stone ballast= 1cum
Brick work 1:7 ratio for 1cum= cement=1bag, sand .25 cum, bricks= 480 nos.
13755
Last answer on 1/26/2017 11:24:59 AM. by
Madhankumar
upendra
3843
comments required
Last answer on 11/18/2021 7:51:18 AM. by
gangula
2395
Last answer on 6/24/2013 9:59:46 PM. Forum started by
software
Vaasku
ESTIMATION
Last answer on 10/17/2012 4:20:51 PM. Forum started by
AHAMED YUSUFF
4797
Last answer on 1/13/2014 2:23:28 PM. by
balaji
2118
construction of multi storey building
Last answer on 8/14/2014 12:08:56 PM. by
Mohan Bhagwat
3178
Estimation software
Last answer on 10/10/2021 12:12:30 PM. by
Lola Cooper
Last answer on 7/12/2018 5:49:08 PM. by
Hameed
1659
please send me south facing elevation of two storied building
Last answer on 5/19/2016 12:34:23 PM. by
jakeer
4013
this is execelant front view,looking varities of front elevation for single sto
Last answer on 12/27/2020 8:48:44 PM. Forum started by
Thakur Pattanaik
2351
software
Last answer on 12/1/2021 6:05:00 PM. by
Last answer on 7/3/2020 11:48:29 PM. by
Mohan
1912
building material
Last answer on 3/23/2015 10:00:27 PM. by
shaheryar
6099
What is construction cost
Last answer on 12/1/2020 5:38:30 AM. by
manoj
1892
column STRUCTURE
Last answer on 11/9/2015 3:11:28 PM. by
DURJOU KUMAR MONDAL
2531
House Plan (50'x50')
Last answer on 11/24/2016 12:15:46 PM. by
Ali Khan
2843
Last answer on 6/17/2013 5:17:52 PM. by
g.s.rajan
2315
this is not a vasthu question ...pl suggest good modern book for frame analysis
Last answer on 1/25/2021 8:27:59 AM. Forum started by
D.Ramachandran
3075
RCC roof
Dinesh Bhadu
1970
Marriage hall construction
chandana kumar
2537
Function Hall
Last answer on 6/14/2021 7:48:53 AM. by
Janette
Mark Paraon
11102
Last answer on 3/16/2021 12:44:03 AM. by
Mohan
2189
Last answer on 11/19/2020 1:18:18 AM. by
Aamir
2037
Estimate
Last answer on 7/3/2020 10:09:08 PM. by
amzad
amzad
3072
Steel
Last answer on 7/2/2020 10:08:44 PM. by
EvaR
use of tmt bar
sonu.211
1642
work turned out by labour
Last answer on 5/15/2017 1:35:22 PM. by
carola braats
2456
estimate
raj
1761
mohd asif
2991
3605
Last answer on 5/26/2016 3:18:53 PM. by
naresh
1943
Cost of Steel construction
Last answer on 4/22/2016 11:27:17 AM. by
VikasUmate
1612
Last answer on 12/17/2015 2:49:59 PM. by
sushantsah
2135
READY MIX PLASTER
Bimlendra Jha
1864
Last answer on 3/1/2015 8:14:42 PM. by
baskar
2223
zero slump concrete
Malik Usman
Specification of Brick
Raw Materials and Scaffolding for ‘Plastering’
Raw material and scaffolding are backbone of 'Plastering' and provide necessary support in construction.
Cement Concrete Raw Material
Read points should be kept in mind while collecting raw materials for cement concrete in construction work.
Orientation of Building
