Home -> Forums -> Construction -> Drainage , Sanitary System and Plumbing -> Explain Q types of trap with sketch?
Tue May 14, 2013Total posts : 1
Naveed zaka
Naveed zaka
Topic: Explain Q types of trap with sketch?
Plz ans this question . i wait of most intelligence answers for most intelligent Peoples. Explain Q types of trap with sketch?
Tue May 14, 2013Post  #1
Dear Zaka
     A trap is a device which is used to prevent sewer gases from entering the buildings. The traps are located below or within a plumbing fixture and retains small amount of water. The retaining water creates a water seal which stops foul gases going back to the building from drain pipes. Therefore all plumbing fixtures such as sinks, washbasins, bathtubs and toilets etc. are equipped with traps.
 Q - trap ;- This trap is used in toilet under water closet. It is almost similar to S trap and is used in upper storey other than ground floor.See link below
o    http://www.gharexpert.com/articles/Waste-Water-Drainage-1790/Traps--Types-Uses_0.aspx
o
2819
Last answer on 2/13/2012 3:19:03 PM. by PR Jawahar. Forum started by pallubc2
2682
commode type and flush type
1778
How I can buy this s trap
Last answer on 6/8/2013 6:14:17 PM. by Navneet Jharia. Forum started by joemon
1799
what is the diffrence between s-trap and p-trape
Last answer on 7/29/2014 2:29:59 PM. by S L Gupta (Civil Engg). Forum started by SANJAY DUSANE
1726
WHICH TRAP IS USED FOR INDIAN AND EUROPIAN W.C.
Last answer on 7/30/2014 9:21:40 PM. by Purvi Panchal. Forum started by SANJAY DUSANE
2065
AS A CIVIL ENGINEER I CAN POST SEVERAL Qs on vasthu ans construction ...but how
Last answer on 3/25/2011 1:19:56 AM. by Nikita. Forum started by D.Ramachandran
2379
I need 16*40 home sketch with vastu please help me
Last answer on 4/25/2013 10:39:22 AM. by Amit Hasija. Forum started by Sharath
2349
Traps - Types and Uses
Last answer on 7/3/2011 1:35:26 AM. by S L Gupta (Civil Engg). Forum started by SHAMS
2177
Simple way for explain Cubic meter
Last answer on 2/18/2011 11:29:37 PM. Forum started by KS T9
2509
Pile Foundation
2379
dampness in bathroom,loft and staircase
Last answer on 8/19/2013 11:25:13 AM. by S L Gupta (Civil Engg). Forum started by Arun
1997
2018
what traps should be used for wash basins and kitchen sinks, enclosed or open?
Last answer on 3/3/2014 12:22:33 PM. by S L Gupta (Civil Engg). Forum started by neelam rathi
1595
do bottle traps get clogged easily and are they easy to clean?
Last answer on 7/18/2014 12:10:12 PM. by seema tyagi. Forum started by neelam rathi
1856
how to see vasthu for street houses with common walls...most of my Qs remain to
Last answer on 8/30/2011 12:16:12 AM. Forum started by D.Ramachandran
2668
i would like to purchase north east corner site, there is connecting 3 roads men
Last answer on 5/31/2012 11:53:24 AM. by Gunjan Utraja. Forum started by LAKSHMINARAYANA
2706
extend horizontally side wall for upper floor
Last answer on 10/27/2014 12:04:09 PM. by S L Gupta (Civil Engg). Forum started by navneet
2996
Plot location
Last answer on 9/2/2019 1:35:07 AM. by s.m.sudhan. Forum started by s.m.sudhan
2339
If i send the sketch of my living hall, would any body help me in decorating it?
Last answer on 9/2/2012 12:29:37 AM. by fatma. Forum started by fatma
1885
tap Connection
3628
sunken slab
2508
How to hire a plumber
3498
1676
2321
3861
flush toilet
1960
4721
Cost estimation for sump tank
2220
water supply
2043
Underground Water storage
2231
sewage pipes
2252
commode & flush type
1949
WC issue
5626
Over-Head water Tank
2337
Vastu for septic tank
2474
Septic Tank Design
3387
3754
position of septic tank
Traps
Proper drainage system is essential for waste water of the house. Traps and water seal are an important part of draina..
Brick Bonds
Do you know good brick bonds can ensure the strength of a building? Only you need to select appropriate bond for walls..
Types of cupola
Let's find details about types of cupola in this writeup
Styles of dormer
This article contains the list of dormer styles.
Types of arch
Kitchen Cabinets
Aluminum
Aluminum door finishes types
There are variety of options for aluminum door finishes available. Let’s get to know the types and recommendation for..
