Wed Jul 11, 2012 | Post #1 | S L Gupta (Civil Engg)
I think that you have left the steel bars from old slab for new slab. If this is the case than overlap the steel bars of old slab and new slab and the over lap length should not be less than 50d. In case you have not left the steel bars than give bearing of the new slab atleast 4'' on the wall and the surface of the old slab should be cleaned and cured before laying the new slab. For more instruction about RCC please visit the website gharexpert. com conc subsection in construction section. | |
Wed Jul 11, 2012 | Post #2 | Ashok Vashisht
Yes, I have left Steel Bars (as an overhang) about 2 feet from the walls edge. Should I weld the overlapping bars for better strength as opposed to tying them with wire ? | |
Thu Jul 12, 2012 | Post #3 | S L Gupta (Civil Engg)
It is not necessary to weld the bars, tye them with binding wires. If you want to weld these bars than care should be taken that the new bar must overlap in 2 feet length and welded at least on three to four points, avoid neck to neck welding i.e. end to end welding which is harmfull. | |
Fri Jul 13, 2012 | Post #4 | Ashok Vashisht
Join date: Jul 2012 | Thanks, Mr.Gupta. That information really helped as I had to decide in case of welding whether I would go for end to end v/s neck to neck. | |
Tue Jul 17, 2012 | Post #5 | Ashok Vashisht
Join date: Jul 2012 | In this context one more question - when the new concrete mix is being laid -
Q1 - Any chemical need be applied to the old concrete edge for better jointing ?
Wed Jul 18, 2012 | Post #6 | S L Gupta (Civil Engg)
There is no need of any chemical to be applied on the old concrete. you should clean the old surface by brush or broom and roughend it by chiseling and wash throughly. Then cure the old concrete and kept it wet by wrping with wet gunny bags well before 2 -3 days before laying the new slab. At the time of laying the slab put shullury of cement and water on the old surface and proceed further laying the RCC slab of your dream home. | |
Mon Apr 20, 2020 | Post #7 | followerswuk
Join date: Mar 2020 | Post subject: Buy Instagram Followers Canada
Interior decoration with pictures by interior expert designers – get interior, exterior, construction ideas and tips from designers and experts at gharexpert BY epicfollowerscanada | |
Questions (39) | |
2992 views | 0 answers | Last answer on 11/3/2011 9:48:40 PM. Forum started by Vijay Godse | 3803 views | 4 answers | Last answer on 12/31/2020 1:23:12 AM. by . Forum started by BHASKAR | 9893 views | 3 answers | Last answer on 9/19/2020 12:43:29 AM. by shaik khaja nayab rasool. Forum started by rishi |
| 6381 views | 7 answers | Last answer on 12/24/2015 4:01:53 AM. by JAI PRAKASH. Forum started by Anu | 3753 views | 4 answers | Last answer on 1/30/2017 12:00:36 PM. by S L Gupta (Civil Engg). Forum started by vinu | 1764 views | 1 answers | Last answer on 2/3/2022 7:29:44 AM. by S L Gupta (Civil Engg). Forum started by Akhil George | 2054 views | 1 answers | Last answer on 2/15/2017 1:14:19 PM. by S L Gupta (Civil Engg). Forum started by Rajkumar | 4647 views | 4 answers | Last answer on 11/4/2021 8:45:13 PM. by S L Gupta (Civil Engg). Forum started by Prem Kant Mishra | 2334 views | 1 answers | Last answer on 6/7/2017 12:17:49 PM. by S L Gupta (Civil Engg). Forum started by Prem Kant Mishra | 3980 views | 1 answers | Last answer on 2/25/2013 11:42:01 AM. by S L Gupta (Civil Engg). Forum started by paresh | 2942 views | 3 answers | Last answer on 5/29/2013 10:29:12 AM. by S L Gupta (Civil Engg). Forum started by Rajesh | 1875 views | 1 answers | Last answer on 8/9/2017 12:11:12 AM. by S L Gupta (Civil Engg). Forum started by Saurabh Agarwal | 3763 views | 2 answers | Last answer on 10/18/2016 5:22:59 PM. by priya. Forum started by A K Sah | 4953 views | 3 answers | Last answer on 12/17/2016 11:39:42 AM. by S L Gupta (Civil Engg). Forum started by Satya | 2255 views | 1 answers | Last answer on 1/27/2015 7:22:56 PM. by JAI PRAKASH. Forum started by FRANCO VAZ | 13755 views | 4 answers | Last answer on 1/26/2017 11:24:59 AM. by Madhankumar. Forum started by upendra | 2033 views | 2 answers | Last answer on 7/29/2015 12:07:00 AM. by JAI PRAKASH. Forum started by jeeveeka | 6412 views | 3 answers | Last answer on 12/11/2013 11:01:19 AM. by S L Gupta (Civil Engg). Forum started by Praveen Srivastava | 2616 views | 3 answers | Last answer on 2/13/2014 11:54:28 AM. by Ahmed. Forum started by Ahmed | 11 views | 0 answers | Last answer on 12/21/2024 12:29:49 AM. Forum started by rupeshji | 8 views | 0 answers | Last answer on 12/21/2024 12:29:40 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:29:32 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:29:24 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:29:18 AM. Forum started by rupeshji | 10 views | 0 answers | Last answer on 12/21/2024 12:29:12 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:29:05 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:28:58 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:28:51 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:28:44 AM. Forum started by rupeshji | 3 views | 0 answers | Last answer on 12/21/2024 12:28:38 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:28:31 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:28:24 AM. Forum started by rupeshji | 15 views | 0 answers | Last answer on 12/21/2024 12:28:18 AM. Forum started by rupeshji | 17 views | 0 answers | Last answer on 12/21/2024 12:28:10 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:28:03 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:27:56 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:27:22 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:27:16 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:27:08 AM. Forum started by rupeshji |
