Home -> Forums -> Construction -> Tips For Color Selection -> Exterior Paint
Exterior Paint
Mon Sep 03, 2012Total posts : 1
arindam kar
arindam kar
Topic: Exterior Paint
Hi
I am constructing my house, and I am bit confused on choosing the exterior paint. I will either choose Asian Paint's APEX ULTIMA or DULUX WeatherCoat, I have read bad feed back about APex Ultima. Can any one share their experience or suggest which colour brand to go with Apex Ultima or Dulux WeatherCoat?
TIA
Arindam
Wed Apr 08, 2020Post  #1
Painting the exterior of your house may seem like a job for professionals, but if you've got the motivation and some basic knowledge of paints, it's a job you may want to tackle yourself. It could save you a lot of cash. Latex exterior paints have undergone improvements, and some can be as durable as oil-based.
Oil-based paints are very durable and water-resistant. They result in hard finish and are often used by professional painters. Use an oil-based if the surface you are painting has already been painted with oil-based paint.
Stir oil-based paint frequently, as the oil in these types of paint tend to separate quickly.
If using oil-based paint, be sure to use a brush or roller specifically designed for use with oil-based paint.
Latex exterior paints have undergone many improvements, and some can be as durable as oil-based.
They are also considerably easier to work with. Be sure, however, that you select an exterior latex for use on the outside of your home, not the same latex used on interior walls.
Tips For Color Selection -Construction Questions (22)
2340
exterior painting
Last answer on 10/13/2010 7:15:37 AM. by . Forum started by aleempasha
2096
can exterior emulsion applied on the inside walls of the building
Last answer on 8/14/2014 10:16:35 AM. by S L Gupta (Civil Engg). Forum started by Shakti Agarwal
2445
exterior painting
Last answer on 3/24/2014 9:24:11 PM. by vamsi. Forum started by Muralidharan
Exterior painting
Last answer on 8/7/2010 11:15:38 AM. by vimal. Forum started by petermm
2578
1803
Last answer on 8/29/2016 12:10:36 PM. by S L Gupta (Civil Engg). Forum started by vishal
3123
Last answer on 1/1/2011 9:02:11 PM. Forum started by A.KIRUBAGARAN
15500
apex ultima vs weather coat? please help me choosing the right exterior paint. a
Last answer on 12/6/2012 11:46:26 AM. by S L Gupta (Civil Engg). Forum started by rajarshi ray
3095
1697
2674
Last answer on 12/31/2020 2:30:00 AM. by uzma. Forum started by jazmin
3725
exterior walls
2356
Last answer on 7/2/2020 9:45:57 PM. by S L Gupta (Civil Engg). Forum started by gianchand
2626
Exterior Walls
3173
2971
Tips for Cement Paint
4519
Wall Putty ,primer and paint
4573
PAINTING
Last answer on 2/24/2022 12:54:30 PM. by Girish. Forum started by Girish
2735
3514
Paint selection
Last answer on 7/3/2020 10:41:47 PM. by Messi1999. Forum started by anwar
1407
selection of right colour for each room
Last answer on 7/3/2020 10:41:11 PM. by S L Gupta (Civil Engg). Forum started by suresh R
4981
Exterior colour combination
Last answer on 7/3/2020 10:37:51 PM. by Nikita. Forum started by rekha
Painting
Exterior paint designs
Picking out the best exterior paint color and design for your home is not as easy as it sounds. Here Are Some Tips for..
Paint
Outdoor
Outdoor Furniture
Do you want to choose right outdoor furniture for your Patio, Backyard or Garden? Here are some ideas for outdoor furn..
How to Plan Outdoor Lighting
How to Design Patio Floor
The patio flooring you choose should be appealing, easy to maintain and durable. Attractive design of patio flooring i..
Outdoor
Outdoor Lighting
Outdoor lighting is essential to light up paths and walkways, outdoors, driveways, pools or other areas and improves s..
Panel
Panel Doors- Advantages and Disadvantages
Panel doors are quite popular in homes for various reasons. Panel doors are hard or provide more security and privacy ..
Hardwood
Hardwood door
Copyright 2007- 2025 GharExpert.com All rights reserved.
