Home -> Forums -> Construction -> Cement Plastering -> Exterior wall Cladding
Tue Dec 21, 2010Total posts : 1
naresh
naresh
Topic: Exterior wall Cladding
We have one of the wall in the Elevation to be highligted with cladding material of Natural Stone or Rockwall. Wall dimensions are 5Ft wide* 50Feet High* 0.5 Ft thick.
Suggest, what material can be used to get this finish
also, mention if it is safe to do stone cladding on such wall.
Pls send details with supplier.
Tue Dec 21, 2010Post  #1
Dear Naresh
   Wall cladding is an encompassing term for the exterior surface of building, which protects the beneath covering against moisture and foreign elements. It is a non structural material for safeguarding internal and external building frontages. Above all it adds natural beauty of stones to the architecture.
        There are so many type of natural stone wall cladding i.e. of sand stone, lime stone, granite stone, kotah brown, marble stone cladding. In these stones there are various types of each type of stone i.e. modak sand stone pink sand stone etc similarly in other type of stone. There are many types of cladding in the rock wall i.e. white quartz, ivory, charcoal etc. Aluminum wall cladding and fiber glass wall cladding rock panels in various design ,sized shapes, light in weight and attractive in color are also available.
Cement Plastering -Construction Questions (39)
2979
details about wall claddings, tiles & all including its rate
Last answer on 10/8/2020 12:45:36 AM. by S L Gupta (Civil Engg). Forum started by laxmi
3694
exterior walls
2591
Exterior Walls
2664
Last answer on 4/26/2021 10:00:27 AM. by mohamed. Forum started by Sanjeev Thakur
2712
3267
Wall Putty on exterior wall
2542
3252
2112
Wall Thickness
4594
WALL CLADING
Last answer on 12/31/2020 2:01:55 AM. by jyoti. Forum started by poonam sethi
3520
stone wall cladding
2642
sir want the detail specification of acp cladding , such as thicknesss of sheet,
Last answer on 1/17/2013 12:27:08 PM. Forum started by somashekhar
2257
wall cladding
Last answer on 7/2/2020 9:46:33 PM. by S L Gupta (Civil Engg). Forum started by ismail
1511
Looking or help on designing the front portion of the house. It can be tiles or
Last answer on 9/22/2017 12:01:52 AM. by S L Gupta (Civil Engg). Forum started by SVasan
4478
beam projection in staircase spoiling skirting
Last answer on 1/2/2021 5:28:12 AM. by Navneet Jharia. Forum started by Durva Mayee
1675
1944
Front elevation design
Last answer on 2/10/2017 12:04:51 PM. by S L Gupta (Civil Engg). Forum started by Jitendra
6765
Best elevation deisgns for west facing two floor house with 30 x 45 feet
Last answer on 4/22/2021 2:52:43 AM. by Michaell. Forum started by K.Ashok Kumar
1823
Last answer on 12/24/2015 4:17:23 AM. by JAI PRAKASH. Forum started by paramesh
2903
Plaster
2764
Plaster work
3035
Plastering
1915
1990
PPC and OPC cement
11230
1854
suggest for exterior
6987
9144
1853
OPC and PPC cement
2136
1992
coarse aggregate
1808
Nice
2419
Gypsum Plaster Vs S/C Plaster
2159
Outer Plaster
2975
putty work on walls
2225
2809
2022
Painting
Paint
Wall
Wall Accents for Your Rooms
Outdoor
Outdoor Furniture
Do you want to choose right outdoor furniture for your Patio, Backyard or Garden? Here are some ideas for outdoor furn..
How to Plan Outdoor Lighting
Home Decorating Tips
Your home is a place where you live, dont make it a workplace, dont mess up. Decorate your home in unique style. Use w..
Exterior paint designs
Picking out the best exterior paint color and design for your home is not as easy as it sounds. Here Are Some Tips for..
Canvas
Canvas Wall Art
