Home -> Forums -> Construction -> Raw Material -> Exterior wall Construction Best method
Wed Sep 28, 2011Total posts : 6
sunny420
sunny420
Topic: Exterior wall Construction Best method
Plzz guide me
What r the latest methods to construct exterior wall of personal double floor residential house without using clay bricks... which r best and can take load also of heavy items like almiroh heavy beds, small safe ,etc r placed on upper floor.
Is Clc bricks (Cellular light weight bricks ) is the good option...for this..
how much load these can take...
Tue Oct 04, 2011Post  #1
ravi at Dalmia
ravi at Dalmia
Hi Sunny, experts would always suggest common burnt clay bricks for construction but people lately have begun to experiment. CLC or the cellular light weight bricks have become very popular in recent times.
- They have a good strength to weight ratio and helps in reduction
  of dead load resulting in saving of steel & cement, also reduces
  the foundation size
- Air conditioning requirement is considerably reduced because of
  a better acoustics and thermal insulation
Consult some experts to get more info on this and if possible see some live examples as decisions like these are made only once for a lifetime.
Good luck :)
Wed Oct 05, 2011Post  #2
sunny420
sunny420
Post subject: Strong ground floor on the upper floor
Plzz tell can clc (cellular lightweight concrete) bricks construction walls & floor can bear load on the upper floor...if heavy weight is loaded on the upper floor  which is easily bearable in the case of bricks construction...
Or plzz tell me
how can we make a proper strong ground floor on the upper floor that can bear heavy load of  wooden and alluminium almirahs, gym home machinery, an office with small goderj safe, etc
Wed Oct 05, 2011Post  #3
Shrinath Rao
Shrinath Rao
With a very good strong mortar plastering, it is possible to have construction of a brick wall which can take the load in first floor.
If load acting on the structure is more, then you can go for reinforced brick wall construction, where you can save money interms of concrete, and also it is a low energy consumed material when compared to concrete.
Wed Oct 05, 2011Post  #4
Dear Sunny
      You should go with RCC Column  and beam at roof level a go with what type of brick you want to use.
Thu Oct 06, 2011Post  #5
sunny420
sunny420
Hello sir
First of all thanks for guiding me...
Now plzz guide
How can we make a good strong mortar plastering...and what r the things to keep in mind for best good strong mortar plastering. Also
Is in the market also we can get any good strong mortar plastering material or solution as some companies are selling. if yes which one is best cost and quality wise...
And what is
reinforced brick wall construction. How it is done...if possible plzz guide me how it save money interms of concrete, and also it is a low energy consumed material when compared to concrete.
Waiting for ur Reply Sir..
Mon Oct 17, 2011Post  #6
Chatar Singh
Chatar Singh
Post subject: Stregthening 4 inch brick wall
I got constructed a 40 feet long 4 inch thick wall section on all sides of a 60 x 20 feet plot. I feel that 4 inch wall is not all that strong although people are constructing 5 storied houses in South Delhi rampantly.
How can I stregthen these walls now that they are already built but not yet plastered?
Do you think Dr Fixit or something are any help?
CS
Attachments: DSC06506.jpg Mon Oct 17, 2011,
DSC06384.jpg Mon Oct 17, 2011,
Image035.jpg Mon Oct 17, 2011,
Image055.jpg Mon Oct 17, 2011,
Image056.jpg Mon Oct 17, 2011,&n
3713
exterior walls
2615
Exterior Walls
2536
931
any new methods for quick construction ??
Last answer on 7/3/2020 10:05:55 PM. Forum started by PAVAN K
4209
Selection of cement ..
2729
3283
Wall Putty on exterior wall
2564
3272
2766
2123
Wall Thickness
1798
Last answer on 8/29/2016 12:10:36 PM. by S L Gupta (Civil Engg). Forum started by vishal
1692
1271
606
What communication methods do builders use in their work? I need to help the con
Last answer on 11/29/2021 9:17:13 PM. Forum started by Kaliopsy
1670
4949
2486
Exterior Wall Crack Repair
Last answer on 12/26/2011 7:13:39 PM. by S L Gupta (Civil Engg). Forum started by S. Kumar
1588
3075
RCC roof
1970
Marriage hall construction
2537
Function Hall
4200
11102
2189
2037
Estimate
11122
3072
Steel
3037
use of tmt bar
1642
work turned out by labour
2456
estimate
1761
2991
3605
1943
Cost of Steel construction
1612
2135
READY MIX PLASTER
1864
2223
zero slump concrete
Painting
Paint
Wall
Wall Accents for Your Rooms
Outdoor
Outdoor Furniture
Do you want to choose right outdoor furniture for your Patio, Backyard or Garden? Here are some ideas for outdoor furn..
How to Plan Outdoor Lighting
Home Decorating Tips
Your home is a place where you live, dont make it a workplace, dont mess up. Decorate your home in unique style. Use w..
Exterior paint designs
Picking out the best exterior paint color and design for your home is not as easy as it sounds. Here Are Some Tips for..
