Home -> Forums -> Construction -> Paints More -> Exterior wall putty
Exterior wall putty
Thu Jan 16, 2014Total posts : 2
Topic: Exterior wall putty
Dear sir, should I apply PUTTY on exterior wall also. I heard it flakes after some time. should I apply directly primer and paint.
Thanx
Thu Jan 16, 2014Post  #1
Ahmed
Ahmed
Hi purvi
You heard it correct, I have exprienced it.
Apply with 2 coats weather proof exterior emulsion with necessary coat of cement primer.
That will be fine
Fri Jan 17, 2014Post  #2
Dear Purvi
           In outer side on exterior surface putty does not hold good due to rains and weather effect but the cement base putty hold good if there is requirement for ratification of plaster surface.Give a coat of cement primer and after it two coats of either cement paint or exterior acrylic emulsion paint.
Paints More-Construction Questions (26)
3284
Wall Putty on exterior wall
8880
2616
Exterior Walls
3713
exterior walls
4627
time for paint and wall putty
3084
2212
Painting interior walls
2565
2730
3273
2992
Wall Putty ,primer and paint
4503
537
wall putty
Last answer on 1/2/2021 5:22:50 AM. by leelindsey. Forum started by paresh
2124
Wall Thickness
2519
4984
One putty mistry told that putty must be done before marble laying on floors as
Last answer on 7/4/2020 3:50:46 AM. by S L Gupta (Civil Engg). Forum started by Surinder Singh
9541
Wall Putty and primer
1897
wall putty
Last answer on 7/3/2020 11:12:22 PM. by JAI PRAKASH. Forum started by ARVIND GOYAL
8880
2412
Very useful Website for all the Professionals whoever involved in Construction F
Last answer on 12/31/2020 2:29:49 AM. by Gunjan Utraja. Forum started by suresh
2177
Painting old house
Last answer on 1/24/2017 12:52:24 PM. by S L Gupta (Civil Engg). Forum started by soumyabrata
1825
wall primer
Last answer on 1/10/2016 9:04:01 PM. by JAI PRAKASH. Forum started by Anu
1892
Wall Putty
Last answer on 3/11/2014 2:11:56 PM. by Abhishek Garg (Builder & Engineer). Forum started by Purvi Panchal
2087
WHAT IS THE COSTING OF VNYLE FLOORING PER SQ FEET.
Last answer on 7/27/2012 1:05:42 PM. by S L Gupta (Civil Engg). Forum started by mksharma
1779
Place to buy cheap paints
Last answer on 10/29/2011 6:35:31 AM. Forum started by judyparker
Painting
Paint
Wall
Wall Accents for Your Rooms
Outdoor
Outdoor Furniture
Do you want to choose right outdoor furniture for your Patio, Backyard or Garden? Here are some ideas for outdoor furn..
How to Plan Outdoor Lighting
Home Decorating Tips
Your home is a place where you live, dont make it a workplace, dont mess up. Decorate your home in unique style. Use w..
Exterior paint designs
Picking out the best exterior paint color and design for your home is not as easy as it sounds. Here Are Some Tips for..
Canvas
Canvas Wall Art
