Home -> Forums -> Construction -> Dampness -> External Wall Seepage in Rainy season
Sun Aug 09, 2015Total posts : 4
Topic: External Wall Seepage in Rainy season
In the rainy season all external walls are very damp (seepage) inside.  All furniture is damaged.
My exterior walls are 8 inch thick brick walls. Plastered both side ( inside and outside ). cracks are not there in plaster.
I want to do any coating or paint from out side. please suggest any option.
Sun Aug 09, 2015Post  #1
gurkirpal singh
gurkirpal singh
Re-Plastering on outside with zero number aggregate mixed and waterproofing (imperno 1 pack for 1 bag of cement or as suggested by the product) will do the job.
Fri Aug 14, 2015Post  #2
Please Experts,
Guide me.
Tue Aug 25, 2015Post  #3
sanjay agarwal
sanjay agarwal
The Solution to seepage problem like yours requires a proper long term
approach,
Clearly in your walls the outer plaster has no waterproof chemical and
that the plaster itself is porous due to higher sand ratio.
Please contact me at 9643450696 for detailed help.
Wed Aug 26, 2015Post  #4
Dear Purvi
         Scrap the old outside plaster and do the plaster with coarse sand in1;3 ratio and finish the top with 1mm thick cement rendering. Also use water proof chemical in mortar.
Also apply cement shullery i.e  cement with water on wall after curing before start of plaster for better grip on old surface.
Dampness-Construction Questions (35)
2105
3386
Seepage into home from external wall
Last answer on 8/4/2012 4:32:08 PM. by S L Gupta (Civil Engg). Forum started by P. Panchal
2083
2130
Walls are damp in rain
2361
estimation
2347
Can we paint House in rainy season
Last answer on 7/25/2012 5:01:52 PM. by S L Gupta (Civil Engg). Forum started by P. Panchal
2025
I had constructed 4" inch wall on the external wall on the first floor what prec
Last answer on 6/26/2019 10:39:50 PM. by S L Gupta (Civil Engg). Forum started by Badhavath Rajeshwar
2566
Removing dampness from wall
Last answer on 7/3/2020 10:31:20 PM. by JAI PRAKASH. Forum started by piyush
2074
outside side wall with 4.5 inch width is suggested or not ? will it cause seepag
Last answer on 7/4/2020 2:24:25 AM. by JAI PRAKASH. Forum started by ashok
2429
how to avoid rain water seepage in 4 inch brick wall any suggestion?
Last answer on 5/21/2015 5:29:55 PM. by JAI PRAKASH. Forum started by ashok
27
Rain Seepage from outer wall
Last answer on 4/5/2011 9:16:46 PM. Forum started by Dr Akshay
2211
2570
Basement Leaks
Last answer on 10/24/2013 11:40:09 AM. by S L Gupta (Civil Engg). Forum started by Purvi Panchal
1875
2523
2196
is it possible to collect all rain water in terrace in the form of rcc duct and
Last answer on 6/2/2013 8:57:21 PM. by Navneet Jharia. Forum started by D.Ramachandran
1374
I want external stair design
Last answer on 4/2/2016 11:25:11 AM. by S L Gupta (Civil Engg). Forum started by pushpak
1692
In East facing home the external stairs for enterance on North East is good or n
Last answer on 11/16/2017 10:34:49 PM. by S L Gupta (Civil Engg). Forum started by Deepshikha Jaiswal
2674
Damp Proofing
Last answer on 12/31/2020 1:53:13 AM. by Mike Perkin. Forum started by VIPIN
3490
How to solve dampness in wall
Last answer on 11/17/2016 10:58:15 AM. by Girish. Forum started by Rajan
1860
Last answer on 12/24/2015 4:06:01 AM. by JAI PRAKASH. Forum started by sushantsah
1491
Canada Goose Chilliwack Bomber much likewise
Last answer on 11/14/2015 12:37:51 AM. by JAI PRAKASH. Forum started by farofaschafer
2105
2130
2083
1885
Damp
Last answer on 4/4/2015 7:00:17 PM. by JAI PRAKASH. Forum started by Jag
1920
Leaking Ceiling
Last answer on 8/25/2014 8:26:28 PM. by JAI PRAKASH. Forum started by sandipvora
2762
1926
bathroom dampness
Last answer on 12/23/2013 12:21:54 PM. by S L Gupta (Civil Engg). Forum started by sunder
2570
Basement Leaks
2531
Reasons of dampness
2365
water treatment for walls
Last answer on 4/27/2011 7:37:34 PM. by S L Gupta (Civil Engg). Forum started by gajender pathak
1748
2086
Last answer on 4/12/2010 8:36:47 PM. by haritha. Forum started by sujani
Hardwood
Hardwood door
Hardwood
Hardwood window
Canvas
Canvas Wall Art
Wall
Wall Decor
Paint
