Home -> Forums -> Interior -> Bedroom -> False ceiling
False ceiling
Sat Jun 12, 2010Total posts : 3
kumar.x123
kumar.x123
Topic: False ceiling
which false ceiling is durable gypsum or PoP? What r advantage or disadvantages of both and approximate cost?
Sat Jun 12, 2010Post  #1
Ahmed
Ahmed
Post subject: POP is good
POP ceiling tiles are durable than gypsum blocks. POP ceiling tiles product is made from gypsum casting powder, reinforced with fibre glass.
There is no any major difference in both of them As advantages and disadvantages are concerned.
Sat Jun 12, 2010Post  #2
modernplasticsco
modernplasticsco
Post subject: PVC is better
I suggest you to use FOAM PVC SHEETS 5 mm and if you require small size like 16 inch x 16 inch 3 mm will do.
FOAM PVC Board is a substitute of a PLYWOOD and its white in colour you can
spray colour of your choice with regular spray gun.
BEST advantage is its water proof / termite proof / and self extinguishing
these sheets are available is different sizes like 6 x 3 , 6 x 4 , 8 x 3 , 8 x 4 etc can CUT with regular cutter as per your wish.
ALSO higher thickness available like 8/10/12/15/18 mm.
It is very easy to put this sheets in a tee section of aluminium.
Mon Oct 19, 2020Post  #3
False ceilings are increasingly being incorporated into modern architecture since they not only lend aesthetic value, but also create visual depth and layers. False ceilings are often known as dropped ceilings as they are literally dropped or hung from the main ceiling. One of the main functions of false ceilings is to conceal wiring, air conditioner ducts and so on. Such ceilings can also be used to delicately divide a large space into intimate sections without building walls. False ceilings accompanied with cove lighting can take the look of any space, be it your living room, bedroom, or dining area, to a whole new level too.
False ceilings can be designed in a number of ways. The most common materials used to build a false ceiling are gypsum sheets or pre fabricated panels. Apart from these, wood panels are also often used to create such ceilings.  You can install false ceilings on your own, or hire a professional if you are not very confident of managing things yourself. In either case, it will help you to be aware of the process of installing a false ceiling. Go through our step by step tutorial for a clearer insight.
Bedroom-Interior Questions (40)
3705
i am looking forward for a book of interiior designing preferably wth pictures o
Last answer on 7/3/2020 11:11:57 PM. by Nikita. Forum started by ravi
4080
false ceiling design needed for bedroom
Last answer on 2/17/2022 3:35:09 AM. by JosephCarlo. Forum started by chandru
10882
how much will it cost to construct a false ceiling
Last answer on 9/15/2021 9:50:00 PM. by ravi at Dalmia. Forum started by Vijayaraj
2604
iwant to see play schools false ceiling designs
Last answer on 7/3/2020 10:06:50 PM. by S L Gupta (Civil Engg). Forum started by manisha agrawal
1933
For doing false ceiling which direction we should bring down/up in desing
Last answer on 2/22/2021 2:30:00 AM. by S L Gupta (Civil Engg). Forum started by PALLAVI
2483
Hi Want to know that in false ceiling how do cove is measured for billing
Last answer on 7/16/2021 7:21:25 AM. by S L Gupta (Civil Engg). Forum started by Sandeep
2750
Last answer on 1/5/2022 8:38:57 PM. by S L Gupta (Civil Engg). Forum started by Hitender Pal Singh
2438
False Ceiling
Last answer on 9/1/2015 2:55:46 AM. by JAI PRAKASH. Forum started by Vijay
2127
Which Material is used in making this False Ceiling ?
Last answer on 3/3/2014 7:22:30 PM. by Shanthakumar. Forum started by Mukta Dubey
2184
False Ceiling--POP or Gypsum, which is better?
Last answer on 5/5/2014 12:08:29 PM. by S L Gupta (Civil Engg). Forum started by ajaywahi
3133
false ceiling
1865
false ceiling
Last answer on 4/19/2015 1:45:40 AM. by JAI PRAKASH. Forum started by avani_nagoree
3061
Last answer on 4/28/2015 8:41:23 PM. by JAI PRAKASH. Forum started by ajaywahi
1934
What is the floor height needed for my living home?
Last answer on 7/6/2013 12:06:05 PM. by S L Gupta (Civil Engg). Forum started by ananth
4764
Last answer on 8/27/2012 4:35:27 PM. by Amit Hasija. Forum started by prakash
2328
HOME INTERIOR
Last answer on 12/19/2012 11:37:08 AM. by S L Gupta (Civil Engg). Forum started by NAVDEEP
3198
What is the specification of skirting and dado ?
Last answer on 12/10/2010 4:06:52 AM. by Shadab Shakeel. Forum started by Jagodish Kr Sarkar
4270
false ceiling for drawing & dining room
Last answer on 2/18/2011 6:53:54 PM. by Nikita. Forum started by arun
2261
id like to know...is this paint or is this whole effect on the roof,given by a f
Last answer on 5/5/2011 5:50:43 PM. by P. Panchal. Forum started by amina
2713
Kids room ceiling designs
6073
20×60
2028
2606
1805
i need to learn 3ds max
2201
Flat interiors
3624
Wall unit
3470
paint
2574
waterproofing
2540
2548
2509
very nice interior
3143
course interiordecoration
2557
Bye Law
6427
3d max
2579
2372
3186
1647
2321
super
2239
Bed design is this best !
Ceiling
Ceiling
Ceiling designs
Dining
Dining Room Ceiling
How to clean plaster ceiling?
What are special types of flooring?
Special types of flooring--Linoleum flooring..............
Kids
Living Room Ceiling
Ceiling
Ceiling Lighting
Ceiling
Ceiling Fans
