Home -> Forums -> Construction -> Outdoor -> Ferro cement Roofing, fly ash bricks, Rat Trap Bond wall, Ferro cement Lintels
Tue Feb 26, 2013Total posts : 0
nasad
nasad
Topic: Ferro cement Roofing, fly ash bricks, Rat Trap Bond wall, Ferro cement Lintels
I am interested in using Ferro cement in the construction of one house (Underground floor (with two store rooms), Ground and first floor) with a plinth area of about 1200-1500 sq ft. Location southern Tamil Nady. Request your advice on using Ferro cement channel for roof cum floor, Ferro cement Lintels, Ferro cement kitchen and cupboard slabs, Fly ash bricks in Rat Trap bond for walls. I have downloaded / obtained brochures with BIS specs for FC Roof channels. However my contractor is not keen on employing these with the pretext that he does not have experience.
Please advise me on using above cost saving practises.
nasad
1785
2705
type of brick
2657
11557
Brick wall and Lintel construction cost per SqFt
Last answer on 6/7/2015 1:27:14 AM. by JAI PRAKASH. Forum started by DD Gandhi
3234
Ferrocement channels roofing Vs Rcc slab
Last answer on 9/15/2021 9:04:11 PM. by S L Gupta (Civil Engg). Forum started by Sameer S Pawade
7005
2930
FLY ASH BRICKS
Last answer on 6/27/2009 12:07:21 PM. by Kranap. Forum started by mamta
9884
6470
9195
3791
1633
sir i have recently consstructed a house using fly ash based cement for ground f
Last answer on 7/28/2015 11:25:48 PM. by JAI PRAKASH. Forum started by baheer din
2456
estimate
1357
Really an informative article on rat trap bond.helping me a lot.just to ask that
Last answer on 12/30/2016 12:59:53 PM. by S L Gupta (Civil Engg). Forum started by sabrina
4627
7512
Brick Advice Urgent
2965
fly ash bricks
4209
Selection of cement ..
2865
Steel calculation
1758
6692
6355
11377
10720
Life span of RBC lintel roof
2090
Foundation
3569
R.C.C. column in Sqft
2279
Plumbing works
1587
New 4 storey building design
1904
earth filling under floor
1773
want a parking
2268
2565
foundation plan.
Last answer on 12/15/2011 2:31:13 PM. by Ishmael Mphande. Forum started by Patrick Salasini
2624
Last answer on 12/6/2011 7:58:37 PM. by Manish. Forum started by Manish
2501
Re-Construction
3013
cracks in walls
Brick Bonds
Do you know good brick bonds can ensure the strength of a building? Only you need to select appropriate bond for walls..
FLY ASH BRICKS
FLY ASH BRICKS
CONCRETE
Traps
Traps - Types and Uses
Proper drainage system is essential for waste water of the house. Traps and water seal are an important part of draina..
