Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> Ferrocement channels roofing Vs Rcc slab
Sat Aug 24, 2013Total posts : 1
Sameer S Pawade
Sameer S Pawade
Topic: Ferrocement channels roofing Vs Rcc slab
My house is constructed 16 years ago in load bearing construction and it is in good condition. I am thinking to construct 2 bed rooms and 1 toilet on first floor with rat trap bond walls and ferrocement roofing channels. will it be structurally stable and strong enough as compared with English bond walls and rcc slab roof?
Tue Aug 27, 2013Post  #1
Dear Sameer
        For strength of wall English bond is necessary. As you want top roof with ferro-cement roofing channel this is good have less load than RCC, but roof is not usable in this case.
4954
9907
3759
3985
Roof leakage
191922
3970
cost estimater
4068
3091
1879
2524
2414
2300
Last answer on 6/16/2021 11:37:22 AM. by S L Gupta (Civil Engg). Forum started by dnyanesh
1988
Last answer on 10/27/2015 10:43:31 PM. by JAI PRAKASH. Forum started by Baba Dedge
2095
11118
1913
6385
kota Stone Roofing
3807
5817
3799
9892
2674
4631
4147
2870
5218
5020
3664
4068
1868
2803
2613
2385
2470
2641
1811
3614
6260
