Thu Jun 06, 2013 | Post #1 | Rudra Nevatia
It is not clear from your post as to the type of ferrocement panels you plan to use. Generally speaking, panels need to be supported on joists, unless your vendor has specially designed them to span the entire width of the building.
As for the roof, a good alternative is Stressed Skin Construction. Please visit
https://docs.google.com/presentation/d/1X1ZUPBfWdkLzP1IUweJesaRdyyjwjCGlbIKvKmQr7v4/present#slide=id.g59b0c90f_0_10
to get an idea about this type of construction. Apart from its cost effectiveness, you can fully utilize the uncluttered space below this type of roof.
Regards, Rudra Nevatia | |
Fri Jun 07, 2013 | Post #2 | Mahesh
Thanks for the reply.
I haven't heard of Stressed Skin Construction.
I originally intended to build flat RCC roof of 4inch thick.
But to reduce concrete , i thought of laying ferrocement panels of less thickness ( around 1 inch). This will help in material cost as well as construction cost. No shuttering/curing required. Just build sufficient beaming and lay the panels on that and then seal it with mortar.
There will be truss roof above the flat RCC, so i am not much worries about leakage issues.
ferrocement panel of 1-1.5 inch thick, 6ftx4ft panels can be laid, i think.
According to me below advantages compared to RCC roof,
(1) less material cost
(2) easy and less cost for construction
(3) No plastering required on RCC roof. can be direcl
(4) Secured and safe inside
My concerns are ,
(1) Is there any cost advantages over RCC roof ?
(2) Will it be strong enough even if a room is constructed in 1st floor ?
I have never used ferrocement and all above thoughts are based on what i read over internet.
In kerala, construction is nowadays very costly. | |
Sat Jun 08, 2013 | Post #3 | Rudra Nevatia
Stressed Skin Construction is just a fancy name for the traditional roofs in Kerala. The main feature is that most, if not all, structural members are within the sloping plane of the roof.
Of course you are very familiar with such roofs. However, you may click here to view some pictures of traditional roofs in Kerala and here for a modern version.
In my humble opinion, Bison board may be a better substitute for ferrocement.
Mon Jun 17, 2013 | Post #4 | Mahesh
Thanks for the advice. I shall consult it with my architect.
My concern with Bison panel is that it is a recent product and not seen around much.
Also it is not re-enforced with metal - like a ferrocement panel ( which is getting popular here).
But it looks like it is good.
A flat roof with panel-roof arrangement is pretty easy i guess. I dont need much terrace space as i have enough land.
-Mahesh | |
Questions (39) | |
3234 views | 1 answers | Last answer on 9/15/2021 9:04:11 PM. by S L Gupta (Civil Engg). Forum started by Sameer S Pawade | 2635 views | 1 answers | Last answer on 7/3/2020 11:21:56 PM. by Gunjan Utraja. Forum started by Abraham | 2850 views | 5 answers | Last answer on 9/19/2012 6:08:49 PM. by tjackson. Forum started by Sujatha Kumar |
| 1752 views | 1 answers | Last answer on 4/6/2011 7:39:01 AM. by S L Gupta (Civil Engg). Forum started by D.Ramachandran | 2397 views | 1 answers | Last answer on 7/29/2014 12:12:50 PM. by S L Gupta (Civil Engg). Forum started by Jacob Alex | 2550 views | 1 answers | Last answer on 11/30/2021 11:44:17 PM. by S L Gupta (Civil Engg). Forum started by c k Ramaprasad | 1837 views | 0 answers | Last answer on 12/12/2011 7:39:57 AM. Forum started by poornima | 2188 views | 1 answers | Last answer on 9/14/2010 4:19:24 PM. by S L Gupta (Civil Engg). Forum started by neha khurmi | 6077 views | 7 answers | Last answer on 2/4/2013 11:53:42 AM. by Sonal. Forum started by Prabha | 2411 views | 1 answers | Last answer on 11/18/2009 5:19:38 PM. by Girish. Forum started by ravi | 2260 views | 1 answers | Last answer on 8/16/2013 1:07:43 PM. by S L Gupta (Civil Engg). Forum started by faroque | 5353 views | 2 answers | Last answer on 7/4/2020 3:03:42 AM. by geetika. Forum started by sujatha | 5358 views | 1 answers | Last answer on 1/13/2014 2:21:22 PM. by S L Gupta (Civil Engg). Forum started by Hemant Tiwari | 2040 views | 1 answers | Last answer on 11/30/2013 12:41:30 PM. by S L Gupta (Civil Engg). Forum started by Mohan | 12307 views | 7 answers | Last answer on 6/27/2010 4:58:24 PM. by Ramen Roy. Forum started by harsh | 2141 views | 4 answers | Last answer on 5/12/2015 2:48:10 AM. by JAI PRAKASH. Forum started by Ankita Narain | 2456 views | 5 answers | Last answer on 2/16/2017 2:07:14 PM. by S L Gupta (Civil Engg). Forum started by raj | 2155 views | 3 answers | Last answer on 1/16/2016 1:09:41 PM. by Akshay Wadke. Forum started by Akshay Wadke | 2969 views | 2 answers | Last answer on 7/3/2020 9:50:41 PM. by JAI PRAKASH. Forum started by chandru | 10 views | 0 answers | Last answer on 12/21/2024 12:29:49 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:29:40 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:29:32 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:29:24 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:29:18 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:29:12 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:29:05 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:28:58 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:28:51 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:28:44 AM. Forum started by rupeshji | 3 views | 0 answers | Last answer on 12/21/2024 12:28:38 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:28:31 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:28:24 AM. Forum started by rupeshji | 8 views | 0 answers | Last answer on 12/21/2024 12:28:18 AM. Forum started by rupeshji | 9 views | 0 answers | Last answer on 12/21/2024 12:28:10 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:28:03 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:27:56 AM. Forum started by rupeshji | 3 views | 0 answers | Last answer on 12/21/2024 12:27:22 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:27:16 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:27:08 AM. Forum started by rupeshji |
