Fiber sheet on the roof
Thu Apr 30, 2015
VIJAY
Topic: Fiber sheet on the roof
Hello
I am planning to put up fiber sheet to cover entire terrace of my house in Ajmer. As of now the terrace is in bad shape so I am considering 2 options (given by various contractors)- (a) getting the terrace repaired- majority of contractors are saying the same (b) getting the house built up from scratch- only few are saying this.
Irrespective of the options above, I think it will be good to have the terrace area covered with fiber sheet to prevent it from getting damaged due to heavy rain.
Please advise if this is the right way to do
If this is the right way to do- please advise which fiber sheet should I buy and how much per square foot will it cost.
Is it durable enough to last for 5 years +
Your reply will be highly appreciated
Vijay
Fri May 01, 2015
Not advised.
4348
rate comparison
Last answer on 7/4/2020 2:15:33 AM. by
aammiitt
aammiitt
8419
Roof Beam crack
Last answer on 7/3/2020 11:35:51 PM. by
Arun
1380
what would be total expense to install rubber sheet on roof of 780 sqft
Last answer on 9/24/2016 12:49:20 PM. by
DHIRENDRA
2304
how to cover the open space 4x4 feet in roof.
Last answer on 6/7/2013 5:06:46 PM. by
Rehan Siddiqi
Last answer on 10/27/2015 11:40:05 AM. by
Karuna
2757
Iron Sheet Roofing
Last answer on 6/2/2012 7:25:01 PM. by
skjain20002000
Mr Marea Itaia
1432
I am planning to build a cost effective house. I like to explore use of metal sh
Last answer on 12/8/2016 12:32:51 PM. by
sasi raman
1961
design of skylight structure for double height hall
Last answer on 6/23/2015 1:00:37 AM. by
nitin_patel
1968
I am looking for a alternate material for my 800sq ft house ROOF- anything to be
Last answer on 12/31/2020 2:51:30 AM. by
amardanait
2138
Roof insulation
Last answer on 9/20/2014 12:13:54 PM. by
sb
2132
Sir I am having a rcc sheet roof of 60*12 feet now the sheets was gone I want to
Last answer on 11/5/2014 12:31:16 AM. by
srikanth
2947
Lightweight Concrete Roofing
Last answer on 10/31/2012 12:32:07 PM. by
Ted Junior
2157
Pre coated sheet roof
Last answer on 7/9/2012 9:30:45 PM. by
Ar. Manoj Ralen
MM JASSAL
1532
Cement Sheet Roof
Last answer on 5/6/2013 11:02:16 AM. by
Narayanan
1678
Roofing costs with corrugated metal sheets
Last answer on 4/4/2015 12:25:19 PM. by
Sunil
1447
Roofing Cost of HINDALCO STEEL SHEETS
Last answer on 5/3/2016 11:35:20 PM. by
sira
1980
north to south face 4 bedroom plans 1800 sheet 48 chorai 35 lainth map images
Last answer on 2/25/2015 9:23:56 AM. by
neelam
2080
Last answer on 10/23/2010 3:33:17 PM. Forum started by
sandeep Dholakia
1762
what is the material of this celing? how can we install fiber obtic inside the c
Last answer on 4/12/2010 12:57:24 PM. by
abokafi
2471
Iron Sheet Roofing
ACC Sheet Roofing
Hammocks
If you are looking for perfect outdoor furniture that is comfortable and versatile for sitting, Hammock may be the rig..
