Home -> Forums -> Construction -> Start Construction -> Filter Sand
Tue May 26, 2015Total posts : 4
Topic: Filter Sand
Hello Everyone,
We are going to start our house construction from next week.
We bought a 2 big trucks sand, but later we got to know that that it is "Filter Sand".
how good is this filter sand ? is there any problems ?
We bought this sand for columns and roof, now we are bit worried.
can anyone please help me how do we manage with this, is there any alternative ? or could we mix anything to it ?
Thanks and regards
Santhosh.
Wed May 27, 2015Post  #1
  The specification of sand is as follows
The sand consists of natural sand, crushed stone sand or crushed gravel stone dust. It should be hard, durable chemically inert, clean and free from organic matter, not containing any appreciable amount of clay balls or pellets and other harmful impurities i. e. alkaline, salt, mica, decayed vegetation, lumps etc.
It should be passed through I. S. Sieve 4.75 MM. It should have the finest modulus 2.50 to 3.50 and silt contents should not be more than 4%. Coarse sand should be either river sand or pit sand; or combination of the two. It should be obtained from Badarpur Sand or Stone dust obtained by crushing hard stones or gravel. It should also be obtained from river bed such as Tajewala , Dadupur sand.
Note: In general the sand particle should be coarser and have minimum silt contents. The silt contents should not be more than 4%.
Caution:
The quality of the sand has more impact on the strength of the structure inspite of the quantity of the cement used.
1) If there is more silt in coarse sand, the strength of cement mortar is reduced from 1 % to 30%.
2) If you take best quality coarse sand, it will give maximum strength
Wed May 27, 2015Post  #2
Thanks  Gupta for the quick answer !
Could you please help me how can i do a test at home ?
is there any easy methods to do a test, if so it would be really helpful.
Thanks and regards
Wed May 27, 2015Post  #3
       For site test take glass pure some sand, than pure water and stir the sand in water for short time than left it to settle. After settling the water you see layer of silt on the top of sand.The silt contents should be up to 4%. The sand should be coarser not fine.
Wed May 27, 2015Post  #4
Thanks, am going to test and let you know the result.
Thanks and regards
Santhosh
Start Construction-Construction Questions (38)
1967
Roof Top Plaster
Last answer on 3/17/2015 6:52:17 PM. by Purvi Panchal. Forum started by Sheshagiri
1886
Last answer on 11/29/2021 2:50:23 AM. Forum started by George Mercier
2914
Sand in Water
3712
2011
coarse aggregate
1762
1456
2327
Sand units
1706
Sand units
1524
Sand units
2101
river sand
16072
robo sand vs natural sand
3008
M-Sand for Plastering
6450
3147
Last answer on 7/3/2020 9:54:13 PM. by S L Gupta (Civil Engg). Forum started by padmaraju
2241
sand alternate for concrete
2306
is m sand adviceable toconstructwith bricks
Last answer on 1/23/2016 8:42:33 PM. by JAI PRAKASH. Forum started by ajitkumar
1574
Hi plz sand me porch detail any tipe
Last answer on 7/4/2020 12:21:48 AM. by S L Gupta (Civil Engg). Forum started by vinod kumar
3294
3309
4444
4002
2234
2715
5196
2388
2310
2012
3207
2058
12529
2177
2025
2743
Swimming
Swimming Pool Filters
How to Maintain Air Conditioner?
Keeping air conditioner in good state is essential to get comfort from scorching summer. This keeps our body and mind ..
Swimming
Swimming Pool Maintenance
Maintenance of a pool is a major requirement that must not be taken lightly. Read this article to know tips on how to ..
Through
How To Repair Cracks
