Home -> Forums -> Construction -> Finishing -> Final Handover
Final Handover
Tue May 13, 2014Total posts : 1
Ilias Ahmed
Ilias Ahmed
Topic: Final Handover
Hi all
My house construction is nearing completion( Tks everyone for their support and comments).
My query is what are the check list of things which I should lookout before taking over from contractor.
I request eveybody to commnet on this however silly it may be.
Wed May 14, 2014Post  #1
Dear Ahmed
           There are so many things to check at the time of completion of house.
Take copy and pen and start from one end and write the incomplete or defective items serial wise.
As like start from front door entry and note that
Door is closed properly, all fittings of door shutter work properly, any defect in paint etc.
Similarly note defect of plaster, paint. Note defect of electric point, waterline point, sever defect etc.
Note the defect of all rooms etc and give the list to contractor and check after rectification.
Finishing-Construction Questions (36)
1992
i am doing my degree as a final year civil engineering in bannari ammman institu
Last answer on 6/26/2014 10:16:25 PM. by Ahmed. Forum started by rohinipriya
2369
i am civil engineerimg student iam in my last yeari am preparing my final year p
Last answer on 10/12/2021 10:36:28 PM. by S L Gupta (Civil Engg). Forum started by sultan
2615
final bill
Last answer on 7/3/2020 10:03:19 PM. Forum started by chethan
1861
Sir,as i am in final year we have to make major project.so i want to know 3-4 to
Last answer on 10/10/2013 4:01:05 PM. by S L Gupta (Civil Engg). Forum started by shailesh yadav
2294
CONSTRUCTION ESTIMATION
Last answer on 4/25/2015 2:17:08 AM. by JAI PRAKASH. Forum started by srinivas kamsali
2075
Last answer on 1/26/2021 9:58:34 PM. by litaka4438. Forum started by Dheeraj Grover
1901
Last answer on 12/25/2020 3:36:39 PM. by S L Gupta (Civil Engg). Forum started by Dheeraj Grover
2529
Last answer on 4/28/2016 11:46:17 AM. by S L Gupta (Civil Engg). Forum started by Dheeraj Grover
1657
Last answer on 4/28/2016 11:45:39 AM. by S L Gupta (Civil Engg). Forum started by Dheeraj Grover
1609
Last answer on 4/28/2016 11:44:25 AM. by S L Gupta (Civil Engg). Forum started by Dheeraj Grover
1780
Last answer on 8/25/2020 10:40:38 PM. by S L Gupta (Civil Engg). Forum started by Muneeruddin Syed
1844
4614
Prevention of Cracks in Gypsum board false ceiling
Last answer on 12/31/2013 12:12:28 PM. by S L Gupta (Civil Engg). Forum started by Dhananjay
1782
THE ESTIMATOR IN THIS PORTAL IS A VERY USEFUL TOOL WHICH CAN ENABLE A PERSON TO
Last answer on 7/7/2020 12:51:18 AM. by S L Gupta (Civil Engg). Forum started by K S SHYAM SUNDER
2349
Traps - Types and Uses
Last answer on 7/3/2011 1:35:26 AM. by S L Gupta (Civil Engg). Forum started by SHAMS
1733
2492
Used M15 (1:2:4) mix ratio with PPC cement for casting ground floor house roof slab
Last answer on 2/21/2017 12:28:02 PM. by S L Gupta (Civil Engg). Forum started by vinu
1763
Cost reduction
Last answer on 9/22/2014 8:51:26 AM. by Unoara Design Hub. Forum started by sanu kumar
2018
Last answer on 2/2/2022 11:26:31 PM. Forum started by manjunath
2592
Elevations Required
Last answer on 2/2/2022 10:53:23 PM. Forum started by gangula
3202
Cracks on the walls
Last answer on 1/14/2022 10:40:04 AM. by S L Gupta (Civil Engg). Forum started by devjani roy kashyap
2897
Wall painting
2083
CEMENT PANI - Plaster Works
1951
Triangle House roof
Last answer on 1/14/2022 4:58:49 AM. by S L Gupta (Civil Engg). Forum started by tayyab
3870
Last answer on 1/14/2022 4:09:54 AM. by S L Gupta (Civil Engg). Forum started by Sameer
2332
tiles or marble
Last answer on 12/4/2021 5:12:27 AM. by S L Gupta (Civil Engg). Forum started by aammiitt
3536
stone wall cladding
1515
help
1542
POP OR GYPSUM
10933
Lappam vs Wall Putty
1932
Last answer on 3/5/2016 9:18:00 PM. by JAI PRAKASH. Forum started by raj
1834
1961
2118
2569
Thermal Insulation of Home
Last answer on 3/29/2010 7:23:40 AM. by abhijeet pawar. Forum started by akkulshrestha
Terrazzo
