Home -> Forums -> Construction -> Pillar Work -> First floor construction
Tue Sep 07, 2010Total posts : 4
chidambar
chidambar
Topic: First floor construction
Hi All,
My Ground Floor house is built without Pillars. I want to go for Pillar construction for first floor.I have space to put the pillars at the external walls ( 25X40 feet) and do not want to disturb the internal of the ground floor. So question is, Is it Okay to put the pillars at distance of 25 feet ? Will the beam between 2 pillars at distance of 25feet take the load?  OR its a risk ?
Chid
Wed Sep 08, 2010Post  #1
Dear Chidambar
            25feet long beam can take the load if required size beam, MS steel bars and concrete mix are done according to structural design and also the columns should be according to loading condition.It is better if you take advice from any civil/ structural Engineer. Gharexpert also provide this service, if you  want take help than send the old house line diagram with the detail requirement.
Wed Sep 15, 2010Post  #2
nirmal
nirmal
Post subject: similar issue
I have a old single floor house made from brick walls. Now i want to build a floor on the existing floor. I want to build the new floor using pillars. Looking for suggestions and also need some expert advise.
Mon Feb 11, 2019Post  #3
pradeep j
pradeep j
Post subject: second floor
hi my self is pradeep j
They have done the  construction for ground and first floor with the pillar
but they have close the pillar for the floor level.
They have not taken the pillar more so i need to built the house second floor&one room for the tank to keep
 so can i built the house without pillar it will safe for long time
so please suggest about this thing
Tue Feb 12, 2019Post  #4
          For seeing the situation correctly send plan of first floor with column and beam than it is possible to comment.
                               Thanks.
4426
first floor construction
Last answer on 11/27/2021 5:54:34 AM. by narendra barde. Forum started by naina
15294
First floor Construction cost
Last answer on 1/4/2013 11:30:16 AM. by S L Gupta (Civil Engg). Forum started by gomathi
3903
construction of 1st floor
6126
Last answer on 10/5/2021 3:01:31 AM. by Alexander Graf. Forum started by ravi garg
2135
I am planning for first floor construction. I need a civil engineer/architect an
Last answer on 7/29/2017 5:22:26 AM. by JAI PRAKASH. Forum started by Chandrasekaran S
1822
Plot size 25*50 please send construction plan for combined family with three cou
Last answer on 5/26/2016 3:34:41 PM. by Beenu Phogat. Forum started by praveen solanki
2406
MY CONTRACTOR IS CHARGING THE SAME RATE OF CONSTRUCTION FOR GROUND AS WELL AS FI
Last answer on 8/22/2013 12:12:50 PM. by Ahmed. Forum started by K S SHYAM SUNDER
2972
duration of constucting home
4108
1982
Dear Sir,I need your advice on the new house, which I have recently booked and i
Last answer on 8/8/2014 10:57:40 AM. by Abhishek Vohra. Forum started by Esha
15360
2nd floor construction
1871
1921
4025
Last answer on 7/8/2019 11:19:25 PM. by S L Gupta (Civil Engg). Forum started by Ashish Ranjan
1986
Water Curing
Last answer on 9/12/2014 9:52:07 PM. by JAI PRAKASH. Forum started by awdhesh
2435
I want to contruct first floor on already existing ground floor with a plinth ar
Last answer on 11/5/2012 3:30:44 PM. Forum started by parvathi
2892
Last answer on 11/5/2012 5:44:56 PM. by krishna. Forum started by parvathi
1950
please send me 55 feet by 58 feet plans,graund floor and first floor
Last answer on 4/29/2015 11:56:29 AM. by seema tyagi. Forum started by Hafiz Abdul
32560
Cost of RCC Pillar
6437
position of pillars
1878
column
1780
First floor plan suggestions
2524
Pillar cost
4036
42125
2501
2503
Length of cantilever beam
2537
RCC column (pillar)
9228
pillar size in distacce
9195
2823
2694
1993
2208
3160
Laping length requirement
Sewerage
Sewerage & Plumbing System
Tips for Cement Paint
Tips for Oil Bound Distemper
