Home -> Forums -> Construction -> Start Construction -> Floor extension
Floor extension
Tue Nov 01, 2016Total posts : 1
meghraj
meghraj
Topic: Floor extension
Hello Gupta Sir,
Thanks for sharing your valuable inputs for all these year. Reading your inputs gives immense relaxation while costing.
Coming to my query, I have G+1 floor house build on 30*40 site in Bangalore. We have 12 columns sizing 9”*16” (4 nos 16mm bars, 2 nos 12mm bars in btw and ring of 8mm), beam size 9”*9” and the Slab thickness is 6”.
Can I construct another floor on this?
If yes, then I am planning to construct another floor of 850 sqft, final floor no more construction in future. My few technical question are, can I decrease the size of the column to 9”*12”? And slab thickness to 5”?
Tue Nov 01, 2016Post  #1
Dear Megraj,
1. You can proceed for another floor and column size is reduce from 9''x16'' to 9''x12''.
2.  Keep Slab thickness 4.5'' to 5''
1866
Extension of floor area in 1st floor
Last answer on 4/21/2015 10:48:31 AM. by seema tyagi. Forum started by ds
2143
2344
House contructed in the plot i have purchased has a southwest corner extension(p
Last answer on 12/11/2021 1:01:47 AM. by sabina vanjani. Forum started by subrahmanyam
5692
2670
1996
Vaastu advice
Last answer on 6/28/2021 8:18:25 AM. by S L Gupta (Civil Engg). Forum started by Muneeruddin Syed
1404
Dear Nageshwar sir / Dear vastu experts, Figure No. 1 is my actual plot which h
Last answer on 7/20/2016 11:16:12 AM. by S L Gupta (Civil Engg). Forum started by Muneeruddin Syed
1699
The south-west corner of my plot is slightly extended. Also in the top (second)
Last answer on 7/10/2011 8:51:15 PM. Forum started by Jayshree Balachander
2039
option other than rcc deck / balcony @ residence
Last answer on 9/4/2014 7:34:32 PM. by D.P.S. Forum started by parth
2352
Check the load
Last answer on 11/17/2013 12:35:51 AM. by Dilip. Forum started by Dilip
1967
while building an extension building next to old one the ceilings were kept apar
Last answer on 8/20/2011 2:20:45 AM. Forum started by D.Ramachandran
2146
Extension at South West and North West, North and North East Missing
Last answer on 10/16/2011 2:42:06 PM. Forum started by Raveen
1332
Extension of rcc roof like L shape and passage of air through air holes.
Last answer on 10/22/2020 11:37:02 PM. by S L Gupta (Civil Engg). Forum started by vinu
1774
Extending the Roof concrete
Last answer on 11/1/2015 7:02:15 PM. by JAI PRAKASH. Forum started by Balan
1922
2373
1599
How much Marole required
3947
need for plan
2468
3312
2236
2312
2061
Terrazzo
Refinishing Hardwood Floors
Checklists for flooring
Comparison
Appropriate
Linoleum
Linoleum Flooring
Linoleum flooring is a popular choice when you are looking for style and ease at the budget. You can choose any color ..
Choose
Choose Flooring for your Kitchen
Kitchen flooring should be fit into the kitchen design in such a way that will work according to your personal needs a..
Oak
Oak Flooring
A beautiful, elegant and sophisticated option of flooring adds to the value of your home. Oak flooring is such a choic..
Drawing
Drawing Room Flooring
