Home -> Forums -> Interior -> Home Improvement -> Flooring solution
Flooring solution
Sat Apr 29, 2017Total posts : 1
Komal
Komal
Topic: Flooring solution
We have concrete floor. We want to improve it by painting it. Plz suggest cheap solutions for it.
Attachments: 14934359585942019250949.jpg on Sat Apr 29, 2017,&n
Sat Apr 29, 2017Post  #1
Dear Komal,
See the detail
Epoxy Flooring
What is epoxy?
Epoxy also known as polyepoxite is a thermo set produced by the bonding of two compounds, the epoxide which is the resin and polyamine which is the hardener. The result of the mixture is a tough sealant that is resistive to chemical absorption.
Epoxy Flooring
What are uses of epoxy?
Epoxy has many uses in the construction industry.
It can be used as paints, coatings and adhesives.  They are handy in carpentry and woodworking which can be a substitute to wood glue. It can be used in situations where quick drying is needed since it sets faster compared to wood glue. Epoxy can also be used in laminating plywood with fiberglass.
Other uses of epoxy are in industrial tooling, electrical systems, marine application and aerospace industry.
Epoxy Flooring
(This picture is contributed by "Swati Sharma")
What is epoxy flooring?
Epoxy flooring may be generally defined as several layers of any type of epoxy resin that is applied on a floor surface. The applied epoxy on the flooring should have a minimum of 2mm in thickness.
Epoxy Flooring
(This picture is contributed by "Nidhi")
What are the uses of epoxy flooring?
Epoxy flooring is applied to places where the floors need to be slip resistant. These places include pedestrian lanes, warehouses, loading bays, and areas where there is constant traffic by load carrying trucks.
This type of floor coating is also used where there is a need for clean, dust-free, easily maintained environments. Facilities that manufacture electronic, chemical, cosmetic and food products are industries that need high sanitary measures.
Epoxy Flooring
(This picture is contributed by "Monu Jangid")
What are the types of Epoxy flooring?
There are three main types of epoxy flooring. The solvent borne epoxy, waterborne epoxy, and the 100% solids epoxy. These categories are according to the type of fluids mixed. Epoxy coatings used on floors can be both applied on the flooring of homes and factories. They are flexible and durable and can form a decorative terrazzo flooring when applied on home floorings.
(This picture is contributed by "Nenni")
Solvent Borne Epoxy is a type of solvent when applied leaves a hard epoxy coating.
The hard epoxy coating is due to a solvent that contains concentrated amounts of organic compounds. This type of epoxy similar to other types of epoxy is cohesive and is capable of having a thin layer when applied to floor surfaces.
There are disadvantages in using solvent borne epoxy. It is combustible and can be toxic when vapors that have evaporated from the solvent borne epoxy are inhaled.
A more environmentally friendly alternative would be the waterborne epoxy. It provides a high degree and resistive coating to concrete and metal surfaces. The waterborne epoxy can easily blend to other waterborne polymers when modified latex adhesives are needed. It can vary on thickness of its application on surfaces and water alone can clean it easily. Though considered safer than other epoxy flooring, it still contributes negative impacts to the environment in a certain degree.
Applying Epoxy Coating....
The 100% Solids Epoxy is a type of epoxy flooring that has the least negative impact to the environment. The drawback to this advantage though, is that, since it is a 100% solids epoxy, therefore it is harder to apply. With having a mixture that has lesser fluid carrier, the viscosity or the tackiness of this epoxy is quite high. Though having this disadvantage, it can still be flexible to certain applications. A need of having a dry run for its use can be advantageous before applying it to a surface.
What are the benefits of using epoxy flooring?
When applied correctly, epoxy floors are extremely durable and resistant to chemical spills, stains and dust. It is also slip-resistant and easily cleaned. The epoxy flooring comes in with several colors that includes clear, slate or silver gray, and can also have specific colors like white or dark based color tinted.
1971
Underfloor Heating - Home Heating Equipments
Last answer on 6/16/2015 4:05:32 AM. by JAI PRAKASH. Forum started by kevinlee
2317
Last answer on 11/19/2013 1:31:03 PM. by Amit Hasija. Forum started by Toby Tyler
3106
2616
Last answer on 4/28/2021 12:23:46 AM. Forum started by Atul Kumar Agarwal
1793
what is the solution/remides if WC in NE
Last answer on 8/7/2011 4:08:53 PM. by sabina vanjani. Forum started by CHANDRASHEKHAR
72
Love Breakup Solution By Astrologer 91-9056562757
Last answer on 4/26/2024 12:21:05 AM. Forum started by Pandit Sahil Sharma Ji
65
Last answer on 4/26/2024 12:21:06 AM. Forum started by Pandit Sahil Sharma Ji
74
Last answer on 4/26/2024 12:21:07 AM. Forum started by Pandit Sahil Sharma Ji
69
Last answer on 4/26/2024 12:21:09 AM. Forum started by Pandit Sahil Sharma Ji
74
Last answer on 4/26/2024 12:21:10 AM. Forum started by Pandit Sahil Sharma Ji
71
Last answer on 4/26/2024 12:21:11 AM. Forum started by Pandit Sahil Sharma Ji
77
Last answer on 4/26/2024 12:21:12 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 4/26/2024 12:21:13 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 4/26/2024 12:21:14 AM. Forum started by Pandit Sahil Sharma Ji
72
Last answer on 4/26/2024 12:21:15 AM. Forum started by Pandit Sahil Sharma Ji
76
Last answer on 4/26/2024 12:21:16 AM. Forum started by Pandit Sahil Sharma Ji
72
Last answer on 4/26/2024 12:21:17 AM. Forum started by Pandit Sahil Sharma Ji
73
Last answer on 4/26/2024 12:21:21 AM. Forum started by Pandit Sahil Sharma Ji
59
Last answer on 4/26/2024 12:21:22 AM. Forum started by Pandit Sahil Sharma Ji
2338
Refinish a Vinyl Floor
2508
Introduction
1077
Home appliances
2350
2952
layout plan
2170
Window Curtains For Home
3409
Reg: Interior design software
4736
2703
Living Room Decoration Ideas
2219
2021
2203
floor tiles
775
Online dating
2527
4019
Paint vs Wallpaper
2500
Design for a pooja room
9517
Wall Putty and primer
1999
Straight Drop Awnings
Kids Room Theme
2002
sapty tank
Carpet
Carpet Cleaning Tips
Storage
Storage Solutions for kids Room
Kids require a lot of storage space to place their toys and playthings. Proper storage ensures safety to the kids as c..
Green
Tips for White Wash
Whitewash brightens walls and perks up the beauty of the house. It diminishes odors and provides sanitary conditions i..
Bathroom Cleaning Tips
Kitchen Storage Ideas
Terrazzo
