Sun Dec 23, 2012 | Total posts : 3 |
| Topic: Footings and Ground Work
Dear Guptaji
I hav a friend who's a builder.
He told me that, commonly, the cost of the footings & ground work will be "30% sft from the total slab area (sft) ".
Example: If the total slab area is 10000sft @ Rs.900/sft, then the total sf for footings & ground work will be 3000sft@ Rs. 900/sft
Is It True Sir???
Mon Dec 24, 2012 | Post #1 | S L Gupta (Civil Engg)
As per your question I under stand about footings i.e. you mean footing of columns but ground work is not clear. In ground work which work you want to take, write your quarry in detail so that one can be able to answer your question properly. | |
Tue Dec 25, 2012 | Post #2 | siddhaanth
What i mean with the term ground work is the "Entire Process" involved in laying a foundation (with columns) and formation of the floor to the plinth level of the ground.
My query is about a G+3 group housing project. Its' total slab area is 10650sft.
At the rate of Rs.900/sft, how much does it cost approximately to complete the above-mentioned "ground work"?
Thank you for your time sir. | |
Wed Dec 26, 2012 | Post #3 | S L Gupta (Civil Engg)
I follow your point, you want expenditure on the foundation of house up to plinth level or floor level. The cost of foundation depends upon many things i.e.
i. Bearing capacity of soil, it means if bering capacity is less than cost of foundation is more.
ii. Cost is also depends on the height of building, i.e. if a building is single story than cost of foundation is less than the multy story building.
iii, If we made earth quack safety meaure than we have to provide plinth beam etc which increase the cost.
iv. Cost is also affected with specification, plan of building etc.
However you can calculate the cost by using gharexpert.com website estimator tool link are given below.
http://www.gharexpert.com/Estimator/Startpage.aspx | |
Articles that might interest you! | | Preliminary Works during Ground Work Entire area should be cleared of all roots, bushes, vegetation etc. for a smooth construction works. | | Designing a Foundation Foundation is the part of structure below plinth level and needs special care while designing. Whole design of the fou.. | | Pool Pumps Pool pump is the most important equipment of your swimming pool. This device works with filter to maintain the cleanline | | Brick Work Brick work is an important part of construction work done with the help of bricks and cement mortar. It is done with d.. | | Checklist for Painting Work Before you start paint work, make sure that the surface is clean of dust, grease and other foreign matter. Decide on s.. | | Surface Preparation and Painting Tips Paint is any liquid, liquefiable or mastic composition which after application to a substrate in a thin layer is conve.. | | Guideline for Labor for Brick Work Foundation We all know the importance of brickwork in any construction, So the article here describes the guideline meant for la.. | | Terrazzo flooring (Mosaic or Marble chip flooring) Terrazzo flooring is popular for residential as well as public buildings since it is not slippery when wet.
| | Guideline for Labor for Brick Work in Super Structure While going for construction, do we know the Guideline meant for Labor for Brick Work in Super Structure? If not then .. | | Guidelines for Plumbing/Sewerage Pipe Works A clean and germ free home is where you live fresh and healthy for long. For a healthy and germ free environment in ho.. | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
