Home -> Forums -> Construction -> Foundation -> Foundation Brick estimate
Sat Aug 03, 2013Total posts : 2
Bs Dhiman
Bs Dhiman
Topic: Foundation Brick estimate
Respected Sir,
                    Sir i need a help of you in foundation estimate of brick.Sir In your estimate i read a colum of Brick work in Foundation in 1:7.In 1000 sqft. 5000 brick.Sir i want to know that how is the depth of foundation? is 2'-6" depth?
Sat Aug 03, 2013Post  #1
Dear Dhiman
           The estimator gives the quantity and cost as per rough cost estimate so that customers can become aware that such detailed estimation is possible. The estimate quantity should ideally be calculated by using the architectural and structural plans. For example if  one person is  planning to build a 3 rooms home where as the other person is planning to build  4 rooms home then  the quantity in foundation will be changed even if both the homes have the same total squarefootage. For actual calculation you should have detail estimate based on the plan of house and on foundation design. The depth of foundation also varies from soil to soil and that impacts cost as well. I f there is hard soil than you can kept foundation from 2.5' to 3'. For detail estimate see the link below
Sun Aug 04, 2013Post  #2
Bs Dhiman
Bs Dhiman
Thank you Sir
2409
what are these 3 types
9195
3272
For Estimate
3669
wals
1885
discussed about the estimate of of bricks in a wall in one square foot
Last answer on 5/20/2015 5:28:35 PM. by JAI PRAKASH. Forum started by bittushaikh
2749
4799
tie beam obsolete
3475
labour charges rates
1797
RCC foundation instead of brick foundation
Last answer on 9/23/2015 8:37:51 AM. by gpeter. Forum started by gpeter
1543
sir, which one is better, brick foundation (as illustrated in your site) or trad
Last answer on 3/5/2016 10:07:27 PM. by JAI PRAKASH. Forum started by Bhupinder Kumar
1859
Foundation -- Urgent
Last answer on 7/29/2014 1:14:27 PM. by S L Gupta (Civil Engg). Forum started by Debojyoti
2865
Bricks
3992
RCC + Brick work estimate for 2400 sq ft construction- Update
Last answer on 5/7/2014 4:12:37 PM. Forum started by nilesh
2632
Dear sir,I need information for RCC Brick work estimate for 2400 sq ft plint
Last answer on 7/4/2020 12:05:21 AM. by S L Gupta (Civil Engg). Forum started by nilesh
3262
compound wall
1853
for superstructure esstimate
Last answer on 8/17/2013 11:27:56 AM. by S L Gupta (Civil Engg). Forum started by Bs Dhiman
2037
Estimate
2684
Pillar
2140
Curing urgent
2372
structure work
5166
Pillar foundation
2203
new house
2821
building a house
1991
Construction Agreement
3090
Foundation
2272
Foundation
1476
10048
3660
Foundation
2115
Structure proof checking
2558
Foundation design
2467
Saria and cement
3656
Wall Thickness
2678
3179
13267
Steel Type
Designing
Designing a Foundation
Brick Arches
Specification of Brick
Bricks Quality
Brick Pillar
Buying tips for Bricks
