Home -> Forums -> Construction -> Start Construction -> Frequent overflow of septic tank / soak pits in an apartment
Sun Dec 08, 2013Total posts : 3
Arun
Arun
Topic: Frequent overflow of septic tank / soak pits in an apartment
We find the soak pits overflowing frequently and needs removal of waste water by 4 to 5 lorries atleast every 2 months.
What would an ideal remedy be for the situation ?
septic tank: 10ftx10ftx10ft (approximate dimensions),
Mon Dec 09, 2013Post  #1
Dear Arun
     For over flow problem is due to many reasons
1 soak pit is old
2 It may be clogged
3.Frequently water flowing in to soak pit and it is beyond the capacity of soak pit.
4. Earlier design for less people to be used but after that load increased.
5. Water table of ground is high.
6. It is better to take help from local engineer for redesigning the system.
Sat Dec 14, 2013Post  #2
Arun
Arun
Dear Gupta,
Please post some septic tank design and explain how to construct septic tank?
Sat Dec 14, 2013Post  #3
Dear Arun
Septic tanks or soak pits are useful for disposal of waste in the areas or houses where public sewerage system is not applicable.See the link below
http://www.gharexpert.com/articles/Soil-Waste-Drainage-Sewage--1817/Septic-Tank,-It%E2%80%99s-Principle-Guidelines_0.aspx
2477
Septic Tank Design
2046
Soak pit location in industrial plot
Last answer on 5/21/2019 1:35:08 AM. by JAI PRAKASH. Forum started by navin
3039
Last answer on 4/1/2013 3:23:48 PM. by akmurty1. Forum started by kjeevanrao
I have septic tank in SW. What is remedies
Last answer on 1/2/2021 5:27:45 AM. by Pavan. Forum started by sunil
2096
Vastu for septic tank
Last answer on 7/19/2013 1:38:06 PM. by S L Gupta (Civil Engg). Forum started by Iswarya.N
2674
septic tank location
Last answer on 9/18/2010 12:27:53 PM. Forum started by kamal
2142
my septic tank in dining hall
Last answer on 4/30/2011 9:39:07 PM. by S L Gupta (Civil Engg). Forum started by rohitraj
2829
What is the right place for septic tank
Last answer on 5/27/2019 1:04:59 AM. by sathish. Forum started by anoop
2106
where septic tank is good in east facing house
Last answer on 10/28/2017 2:01:08 AM. by Shailendra Srivastava. Forum started by akshay
959
east facing one side plot septic tank loction
Last answer on 7/3/2020 10:54:55 PM. by S L Gupta (Civil Engg). Forum started by Bhagchand Chhipa
1853
1914
Last answer on 10/7/2020 10:22:43 PM. by S L Gupta (Civil Engg). Forum started by siva
1619
Sir,According to my house plan, I have to construct 3 nos of pillars inside my h
Last answer on 10/8/2020 11:50:18 PM. by S L Gupta (Civil Engg). Forum started by nihar hota
1600
IS THERE ANY DIFF. IN CONSTRUCTION CHARGES WITH MATERIAL FOR MUMTY , SEPTIC TANK
Last answer on 10/20/2016 12:44:55 PM. by S L Gupta (Civil Engg). Forum started by ANIL AGRAWAL
2569
septic tank or sum
Last answer on 6/9/2021 9:43:39 PM. by JAI PRAKASH. Forum started by rohith shetty
2844
I am constructing a house in north face plot please send right position of septi
Last answer on 3/31/2012 8:53:58 PM. by J J Gupta. Forum started by J J Gupta
6665
How to Build Septic Tank for house
Last answer on 9/20/2012 5:51:39 PM. by PR Jawahar. Forum started by P. Panchal
2206
My house is under construction kindly advice the position of septic tank.Option
Last answer on 9/7/2010 5:46:10 PM. by sabina vanjani. Forum started by piyu sur
3385
according to vastu where should septic tank should be place..??
Last answer on 7/29/2009 11:39:05 PM. by Veena Gil. Forum started by priyanka
2480
3305
3318
4449
4020
2246
2724
4233
5205
2394
2319
2023
2463
2141
3214
2073
12540
2187
2029
2748
Vastu for Water Tank
Preventive
Reasons of dampness
Sewerage
Sewerage & Plumbing System
Importance
