For G 2 residential building, column size 9"*15",16mm 4rod,12mm 2rod used.. hori
Thu Aug 22, 2019Total posts : 2
Sathya
Sathya
Topic: For G 2 residential building, column size 9"*15",16mm 4rod,12mm 2rod used.. hori
For G 2 residential building, column size 9"*15",16mm 4rod,12mm 2rod used.. horizontal distance between column is 17'.vertical distance is 11'... Is this ok? plinth beam 15"*9",16mm 4rod,12mm 2rod Lintel 4"inch 10mm 4rod used.Roof beam 12"*9", 12mm 4rods used..
Thu Aug 22, 2019Post  #1
Sathya
Sathya
Kindly refer my attachment,
For G+2 residential building, M15 grade used ,for roof M20grade used
Plinth beam size for building area 9''*15'', 16mm 4rod,12mm 2rod( inbetween C1)
Plinth beam size for stair & portico area 9''*15'', 12mm 6rod( inbetween C2)
Pillar size C1- 9''*15", 16mm 4rods, 12mm 2rod,8mm rings
C2 9"*12", 12mm 6rods,8mm rings
Horizontal Distance between column is 17' & vertical distance is 11'.
Lintel beam 4.5" inch 10mm 4rod
Roof beam  for building area
9"*12",12mm 4rod ( inbetween C1)
Roof beam for stair & portico
9"*15", 16mm 6 rods (inbetween C2)
Roof slab 6inch M20GRADE
My question is
1) is this correct for G+2? Ground floor is already done...now I wish to go for first and second floor?
Attachments: 1566523533754-1334146045.jpg Thu Aug 22, 2019,&n
Fri Aug 23, 2019Post  #2
Dear Madam,
              It is good if you contact any structural engineer of your town who can give better advice after visiting the construction site.
                          Thank
Kindly refer my attachment,For G 2 residential building, M15 grade used ,for roo
Last answer on 7/4/2020 2:29:32 AM. by S L Gupta (Civil Engg). Forum started by Sathya
928
Last answer on 7/2/2020 9:41:30 PM. by S L Gupta (Civil Engg). Forum started by Sathya
1058
Hi All,Is there any difference in strength of column, if we use 8 no of 12mm rod
Last answer on 8/20/2018 12:42:59 AM. by S L Gupta (Civil Engg). Forum started by vishal singh
1042
Last answer on 8/20/2018 12:41:32 AM. by S L Gupta (Civil Engg). Forum started by vishal singh
4651
for g+2 floors 12mm 6rods is ok in 1 pillar? or do i need to buy 16mm 6rods in 1 pillar ?
Last answer on 5/24/2017 11:55:40 PM. Forum started by dreamzy
6881
2650
Cost of construction of roof slab.
Last answer on 9/13/2013 11:42:05 AM. by feroz khan patthan. Forum started by suhas
1293
Column Bars Specifications Reqd
Last answer on 6/2/2016 10:53:49 AM. by S L Gupta (Civil Engg). Forum started by Pankaj Varshney
3795
3134
3510
3610
3033
2260
m15 cost vs m20 cost
2684
Pillar
1604
Respected Sir,We are constructing a individual house at an area of approx 450sq
Last answer on 12/2/2016 11:53:14 AM. by S L Gupta (Civil Engg). Forum started by ranjeet
1531
Last answer on 12/2/2016 11:43:21 AM. by S L Gupta (Civil Engg). Forum started by ranjeet
Column sizes for Individual House with G+2 design
Last answer on 7/12/2016 1:46:04 PM. Forum started by Venkat
24
28
Hard
Skylight
Types of Cement
Orientation
Orientation of Building
