Home -> Forums -> Construction -> Plumbing -> GI Pipes or PVC PP- pipes for home plumbing
Mon Apr 19, 2010Total posts : 1
narender
narender
Topic: GI Pipes or PVC PP- pipes for home plumbing
Kindly advice me which pipe  is good for home plumbing GI(Jindal) or Plastic pipes (Indo Green PP-R hot & cold water from Supreme Co.).
I read about the PP-R plastic pipes co. claim its life is more than  50 years and GI pipe life is only 20-30 years.
Kindly advice me which pipe should I use.
Narender
Tue Apr 20, 2010Post  #1
Post subject: Reply-GI Pipes
Dear  Narender,
UPVC pipes are being increasingly used now days because of a number of advantages such as light in weight yet strong, easy to transport, good flow, corrosion resistant, unaffected by fungi or bacteria and resistant to wide range of chemicals etc.
G.I. pipe hold good in lying in open i.e. on the surface of wall or floor where as UPVC pipes need special care at the time of laying the pipe line to save it from breakage and not hold good in open. UPVC pipes are good for water temperature ranging from 1 to 45 degree centigrade, at higher temperature; the strength of pipes reduces where as G.I. pipes hold well on all temperature.
S.L.Gupta
Plumbing -Construction Questions (39)
2942
SIR, I AM CONSRUTING MY HOUSE IN PATIALA AND CONFUSE THAT WHICH PIPE GI , PVC ,U
Last answer on 1/18/2012 8:33:27 AM. by ravi at Dalmia. Forum started by HARISH SAHNI
1826
2342
what is the diffrence between u-pvc ans pvc pipes
Last answer on 7/31/2014 7:59:31 PM. by GUNA. Forum started by SANJAY DUSANE
1989
PLUMBING
2100
1781
My house is under construction and i have to go for plumbing therefore i want to
Last answer on 9/17/2014 10:59:54 PM. by JAI PRAKASH. Forum started by Avinash Sharma
2083
GI pipe Vs CPVC pipeline
2230
sewage pipes
11189
Which plumbing pipe best for residential purpose?GI(Jindal C/TATA C)alont with (
Last answer on 4/22/2016 11:45:48 AM. by S L Gupta (Civil Engg). Forum started by Sunny Bansal
3805
cpvc pipes v,s gi pipes
2931
4076
drainage pipe line for toiletfor south facing house
Last answer on 1/19/2022 6:35:06 AM. by S L Gupta (Civil Engg). Forum started by ajitkumar
3267
2177
can waste pipe pass the inner maingate ?
Last answer on 12/31/2020 2:33:37 AM. by S L Gupta (Civil Engg). Forum started by ankit gupta
1618
1497
Last answer on 1/17/2015 11:33:39 PM. by JAI PRAKASH. Forum started by mohit kumar
1494
2625
How to hide Rain water pipe
2386
Sewage and drainage lines
6271
Water Tank Quality
3114
Hot Water Tank
2915
Sand in Water
3380
Diverters for Bathroom
2562
2145
40516
2083
2931
1755
2080
Toilets
1988
Wall mounted cummod vs normal
5055
2775
2388
1856
3076
Swimming pool
2541
water softner
2682
commode type and flush type
4193
to shut off water to house
Sewerage
Sewerage & Plumbing System
Checklist for Plumbing
General
Vinyl
Vinyl Flooring
