Home -> Forums -> Construction -> Foundation -> GROUND WORK
GROUND WORK
Wed Sep 23, 2015Total posts : 2
sumit
sumit
Topic: GROUND WORK
wHAT IS THE LEVEL OF DPC FROM THE GROUND?
Wed Sep 23, 2015Post  #1
Dear Sumit
         The level of DPC is at the flood level point of that area, it means that in the heavy rain what is water level standing in the street.
2. Position of level in the surrounding area buildings.
3. The street or road level of the area.
BUT  IT SHOULD NOT BE LESS THAN 1.5 TO 2 feet.
Wed Sep 23, 2015Post  #2
1.5 feet is good.
2190
Footings and Ground Work
Last answer on 12/26/2012 11:46:36 AM. by S L Gupta (Civil Engg). Forum started by siddhaanth
1745
Yes,I want more information regarding architecture design, working design & grou
Last answer on 8/26/2020 3:09:30 AM. by JAI PRAKASH. Forum started by prakash thakur
1571
I want more information regarding architecture design, working design & ground f
Last answer on 4/22/2021 11:03:06 PM. Forum started by Srinivas
1667
Last answer on 10/5/2016 8:18:52 PM. by Srinivas. Forum started by Srinivas
3200
Ready Mix Concrete
5086
4107
3397
Bathroom Cleaning Tips
3651
1821
1362
SirAfter construction of the basement slab, can the pillar work for the ground f
Last answer on 9/4/2017 12:35:46 AM. by S L Gupta (Civil Engg). Forum started by Joseph Santhosh
3107
Last answer on 10/5/2020 10:59:59 PM. by S L Gupta (Civil Engg). Forum started by DEVANSU
4443
lobar work quantity
3614
if i fix some labour rate with petty contractor of covered area of building wit
Last answer on 12/29/2010 12:36:10 PM. by S L Gupta (Civil Engg). Forum started by sudhir singh
2572
1597
How much Marole required
2366
Types of Soil
Last answer on 7/3/2020 11:36:07 PM. by S L Gupta (Civil Engg). Forum started by gpeter
2158
2684
Pillar
2140
Curing urgent
2372
structure work
5166
Pillar foundation
2202
new house
2821
building a house
1991
Construction Agreement
3089
Foundation
2272
Foundation
1476
10047
3660
Foundation
2115
Structure proof checking
2558
Foundation design
2459
2467
Saria and cement
3656
Wall Thickness
2678
3179
13267
Steel Type
Preliminary
Pool Pumps
Checklist
Checklist for Painting Work
Surface
Terrazzo
Inground
Inground Swimming Pool
