Home -> Forums -> Construction -> Start Construction -> Ghar Expert Estimator Tool questions
Fri Jul 03, 2009Total posts : 2
j smith
j smith
Topic: Ghar Expert Estimator Tool questions
I have a few questions regarding the Estimator:
1. formerly it used to have estimator for different cities - Chennai and Kolkatta I believe.  Now it is just Delhi.  Are there any plans to add other cities, specifically Bangalore is what I am looking for.
2. The costs in the estimator - do they reflect the latest values, how often are these numbers updated in your database.
3. I did one estimation and the costs that it shows seem to be quite low as compared to discussions on other boards by a factor of close to 2.   How can I find out what is the actual value in the current times.
In the end, I know we need to get an architect and contractor who will do the estimation, but I want to have an idea before I start my budgeting and applying for loans from the bank.
thank you very much.
Fri Jul 03, 2009Post  #1
Dear Mr. Smith,
Thanks a lot for posting to the GharExpert forum section.  Here are the details about the Estimator.
1) The cost estimator tool provides 2 types of information, the quantity of material required and the rates in an area. The quantity of the material required for a construction job remains consistent however the rates of the raw material vary from place to place and we currently update the rates in Delhi area only.  For other areas, you can cross check one or two raw material items and understand the approximate variation from the Delhi rates.
2) The cost of the estimator reflect the latest values with a tolerance of 5%.  The idea is to provide a rough estimate to the reader so that he understands the various options available to him and the cost associated with it.
3) The cost of a construction job depends on the specification of the job. For example, if you choose cement flooring in cost estimator it might cost upto 1/4th compared to marble flooring. So once you enter the specifications correctly you would see that the cost estimator would return a very close estimate.
The idea of the estimator is to let users play with the various options, understand their relative advantages and disadvantages and the cost implication of the various options. Along with each option we have articles that explain the best practices associated with each process or material.
Please let me know if you need additional information.
At this point we would also like to note that we have a paid service of "Detailed Cost Estimate" where we provide a detailed estimate based on the architectural plan of the building. In order to prepare this estimate we research the prevailing rates in the area and calculate every minute detail about the project.
A sample of the detailed cost estimate is available at the link below.
http://www.gharexpert.com/include/sample_estimate.pdf
You can order the service through the link below.
If you need Architectural or Interior Designing services, please send your requirement to Support@GharExpert.com so that we can connect you to the  relevant teams for further execution.
Gunjan
Sat Jul 25, 2009Post  #2
ksk
ksk
Post subject: Cost estimate only for finishing job
Hello
I s there a way I can get detailed cost estimate only for finishing job including the following
a) Tile Works
b) Electrical Works
c) Plumbing Works
d) Paint Job
e)Wood Works( Door and Windows)
f) Kitchen Work
g) Plaster works
h) Compound and Gate
What will be cost for the same
KSK
1908
hello, i am very much thankful to ghar experts team an very much impresed,my re
Last answer on 2/26/2011 11:30:30 PM. Forum started by waseemkapra
2575
1811
what re these in gharexpert estimates
Last answer on 12/17/2015 2:57:41 PM. by JAI PRAKASH. Forum started by sushantsah
1606
Dear sir iam already taking part in giving solution to que.asked seen on GHAR EX
Last answer on 8/2/2016 11:44:40 AM. by S L Gupta (Civil Engg). Forum started by SANJAY DUSANE
3213
1789
THE ESTIMATOR IN THIS PORTAL IS A VERY USEFUL TOOL WHICH CAN ENABLE A PERSON TO
Last answer on 7/7/2020 12:51:18 AM. by S L Gupta (Civil Engg). Forum started by K S SHYAM SUNDER
1677
tool that add a valveto a 3/4in copper pipeunder pressure
Last answer on 1/17/2014 12:12:34 PM. by S L Gupta (Civil Engg). Forum started by anthony rodriguez
2154
1816
My suggestion to the Ghar Expert. Rates per unit filled in Estimator (default v
Last answer on 10/23/2012 9:24:22 PM. Forum started by pankaj sharma
2823
Super Structure construction
Last answer on 9/25/2020 4:33:02 AM. by S L Gupta (Civil Engg). Forum started by aryan
1764
Dear Vastu Experts,its a really good place to have questions to be posted and ge
Last answer on 6/29/2013 11:00:54 AM. Forum started by Aravind
1645
Hello, To all the vastu experts,i have a question regarding my stair case
Last answer on 2/4/2015 1:25:21 PM. by S L Gupta (Civil Engg). Forum started by shilpa
2514
Smart and Handsome Personality in Ghar Expert
Last answer on 1/5/2022 4:57:23 PM. by Nitin Kumar Barawal. Forum started by Nitin Kumar Barawal
3805
Masonry tool ADZE
Last answer on 12/31/2020 1:57:31 AM. by Boovarahan S. Forum started by Boovarahan S
2269
can i know what the tools u used for this pain..its amazing one?!
Last answer on 5/4/2010 7:27:58 PM. by Ajit Tareeka. Forum started by rasha
2410
Where can I find investing tools for cryptocurrency? Does anybody here know the
Last answer on 11/23/2021 7:57:24 AM. by jackthot. Forum started by ?rdyamk
5872
Estimation
2046
pl see this nice question.....or a doubt..ican naarate how somebody in house wit
Last answer on 12/7/2021 2:15:00 AM. by sabina vanjani. Forum started by D.Ramachandran
4913
ager ghar vastu k vipareet ban gaya hai to kuch upay hai
Last answer on 11/8/2010 4:16:52 PM. by alkasand. Forum started by abhishek verma
2479
3302
3318
4449
4018
2243
2722
4233
5204
2392
2318
2021
2463
2140
3213
2070
12538
2185
2029
2748
Linoleum
Linoleum Flooring
Linoleum flooring is a popular choice when you are looking for style and ease at the budget. You can choose any color ..
Gardening
Gardening Tools
Are you beginner in gardening and don’t know about gardening tools? To properly maintain your garden, you should have ..
Which tools are recommended for Terrazzo flooring?
Tools for Terrazzo Flooring--WOODEN MALLET:- Usually used to knock wooden pieces together, or to drive chisels into st..
The following tools are recommended for door, windows and ventilator frames:
Which tools are recommended for POP?
Finishing trowel: It is used for spreading and leveling plaster on the surface.
Why
Why question answer section was converted to a paid service?
A lot of users have been asking why the question answer service was converted to a paid service and here are our thoug..
What are various tools used for the installation of Fluorescent tube light?
Fluorescent light tubes come in many shapes and sizes. An increasingly popular one is the compact fluorescent light bu..
