Green
architecture curtails unnecessary consumption of resources amplifying your
comfort and quality of life. Moreover with growing awareness of environment,
the architects and engineers in Coimbatore have joined the bandwagon to
construct green buildings.
Advantages of Green Building:
Cost: There is no significant
difference in prices between green structures and regular buildings. Though the
upfront expenses are higher, during their usage they save so much energy that
the money spent on their creation returns at least 10 folds over the time.
Energy efficiency: Studies proved that structures
which are built with wood have lower energy consumption than concrete
construction.
Water efficiency: Optimal water consumption is another
objective in sustainable buildings. With a view to minimize the wastage of
water villas and bungalows in Coimbatore
have adopted recycling rainwater and other conserving fixtures.
4. Material efficiency: Green buildings are built
from ecological, renewable, non-toxic, reusable and recyclable materials e.g. cork
for floorings, etc.
5. Temperature Regulation: Building materials like asphalt, concrete,
etc. cause urban heat island effect. However, this can be compensated by more
green areas around the edifice such as green roofs and rain gardens.
6. Indoor air and environment quality: Fresh air and improved environmental
circumstances create healthy milieu. Moreover, in corporate settings, it
improves productivity by enhancing employee attendance. Hence, greater emphasis
is put on the aeration or ventilation systems while building eco-friendly
structures.
7. Maintenance: Green architecture requires
less maintenance as natural sources that are used during its construction have
longer shelf life.
8. Elevated Property Value: Eco-friendly buildings
have low energy cost but a high sale value due to its sustainable components
and almost negligible or zero consumption.
9. Tax profit: Many tax provisions are in
place that promotes green architecture.
10Superior Retail Sales: Using skylights instead
of electric lighting gives higher sales with less cost. Thus, green
constructions can truly make money.
Disadvantages
of Green building:
1.
Air-cooling features: Indoor temperature
controlling components don’t exist in green buildings. Moreover, the natural aeration
cannot be regulated.
2.
may need correct structural orientation to have proper supply of natural light.
3.
Availability of materials: Green materials are not readily
available. Moreover, transportation fees or cost for shipping and handling may
be very high.
4.
Time: It takes more time to
build a ecological structure. One reason may be due to unavailability of materials.
5.
Green roofs: Green roofs consist of
several layers. Plus, they are heavier than simple ones. So a strong structure is
required to build this type of roof correctly.
6.
Expenditure: Green architecture is
cost-prohibitive. However, with energy saving possibilities it becomes
affordable.
Thus, to achieve better results, one
must hire a sound architect in
Coimbatore that build a dwelling for you considering all the environmental,
economic and social advantages and disadvantages listed above.
