Green Homes-Green Earth
Fri May 22, 2009Total posts : 3
Topic: Green Homes-Green Earth
Green Earth is every body's responsibility and it starts from how green our home can be.  In this forum I invite all of you to share your opinions  about how we can make our homes green.  you could do any of the following.
1) Share your experiences
2) Link to good articles/knowledge you find on the web
3) Or just write about what you would love this World to do.
Enjoy
Fri May 22, 2009Post  #1
Administrator
To start the thought process, here is a link to one article on GharExpert.com
Green Home Design tips
Mon May 25, 2009Post  #2
Karan
Karan
Post subject: 25 ways to create a green and healthy home
You can make your home green by saving electrical energy, cleaning air and also by using non toxic products and which can make your home healthy. You can find more tips to make your home healthy and green.
Sat Nov 21, 2009Post  #3
Girish
Girish
use of bio degradable products more as much as possible
I am currently handling one LEED project.
replaced the use of  nylon ropes we use on sites with coir ropes (specially coir ropes last long than nylon ropes on hot climate)  for demarkation and path marking
use of Areca leaf plates instead of polystrne plates for staff and workers.
use of fly ash in concrete mixes
green color bed room
Last answer on 6/24/2010 5:19:52 PM. by jyoti. Forum started by RITIKA
2065
how much green paint required in 1sqm
Last answer on 7/8/2011 8:24:30 AM. by Abrar Ullah. Forum started by sherab tenzin
1873
can combine colours light green,wine and blue.if not your suggestion
Last answer on 9/8/2011 11:14:07 PM. Forum started by der
1782
1804
Last answer on 7/4/2020 2:05:29 AM. Forum started by Alisson Chan
2135
i have an idea of using this green for my sitting roon, but i have used black ti
Last answer on 2/8/2011 5:03:56 PM. by Nikita. Forum started by josephine
1763
which is the plant with light green bright leaves here...
Last answer on 9/20/2010 1:51:29 PM. Forum started by Arunima
3294
I am selecting parrot green laminate for my kitchen, what other colour will comp
Last answer on 7/22/2020 9:25:43 PM. by sheik ibrahim. Forum started by pranju11
1757
hi..want to have info about green interior?what is all about and what are the co
Last answer on 6/27/2009 11:48:20 AM. by minks. Forum started by teena mayal
3606
my bath room size is 9x9 i want green colour bath room fittings is it possible i
Last answer on 12/31/2020 2:26:23 AM. by misha. Forum started by nagarathna
2021
2442
is green chilli plants are good in kitchen garden as per vastu?
Last answer on 11/23/2015 11:22:47 AM. by S L Gupta (Civil Engg). Forum started by Arvind Ajmera
28705
Good Plywood for woodwork
Last answer on 10/26/2016 8:39:11 PM. by JAI PRAKASH. Forum started by raghuam
3187
Architect to Build Green Modern Home in Bangalore
Last answer on 11/21/2021 1:07:48 PM. by fabions. Forum started by rahulsharma
3513
Last answer on 7/3/2020 9:53:22 PM. by seema tyagi. Forum started by Modern Homes
2072
Last answer on 10/15/2014 8:31:38 AM. by SANJAY DUSANE. Forum started by naresh
3304
Daughter's Bedroom Paint Color
Last answer on 9/20/2010 7:17:51 PM. by Gunjan Utraja. Forum started by Kathy
3482
2348
Share your whitewash experince
Last answer on 12/31/2020 2:01:42 AM. by Sanjeev Thakur. Forum started by gungya
30
hUsBaNd =//=wIfE[[ 91-8769373431]]=//=Divorced problem solution
Last answer on 1/7/2025 11:20:19 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:20:12 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:19:56 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:19:49 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:19:43 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:19:37 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:19:30 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:19:24 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:19:16 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:19:10 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:19:04 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:18:58 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:18:51 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:18:45 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:18:38 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:18:32 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:18:26 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:18:18 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:18:11 PM. Forum started by rupeshji
Husband Wife 918769373431~LoVe PrObLeM SoLuTiOn
Last answer on 1/7/2025 11:17:54 PM. Forum started by rupeshji
Green
Green
Green Your Home
Do you want to make your home energy efficient and environment friendly? Make use of energy saving equipments and opt ..
Earth Filling
Earthing
Balcony
Balcony is an extended platform that projects from a wall(interior or exterior) of a building, supported by columns an..
How does earth quake affect the building?
The outer shell of the earth called lithosphere is broken into plates which are in constant motion, moving at about th..
Which are various types of faults in electrical fitting?
These are three types of faults in electrical fitting: .Open Circuit Fault .Short Circuit Fault .Earth fault and ..
The Five Elements In Feng Shui
The Chinese recognise 5 elements which arise out of the interplay of yin and yang. Ideally there should be a balance o..
