Grill types for Open Balcony
Wed Jun 17, 2015Total posts : 4
richlyn
richlyn
Topic: Grill types for Open Balcony
Please suggest what grill types  to be used for balcony open to rough weather. I have a RCC flat roof.
Thu Jun 18, 2015Post  #1
       For balcony you can fix either iron grill or steel grill. Grill should be made of MS flat or iron square rods properly welded and fixed in cement concrete. See the distance of flats should not more than 12'' for safety of kids.
Thu Jun 18, 2015Post  #2
Use MS (need maintenance and cheap) or SS (No maintenance and costly) grill as per your budget.
Thu Jun 25, 2015Post  #3
richlyn
richlyn
Thanks for your Guidance.
Also what would you suggest for Terrace railing?
i checked the market and found marble pillars ranging from 200 and above while cement ones start from 150 per pillar.
however i am looking at longevity of the material.
Fri Jul 03, 2015Post  #4
Both are not so good and not in trend, go for SS.
Marble is better than cement.
I woulk like have assistance in getting my kitchen designed which is an open kit
Last answer on 1/21/2022 4:02:14 AM. by TanyaHerrera. Forum started by mukesh k
3344
Tips for Office Furniture
Last answer on 1/8/2022 3:03:34 AM. by Sandy Parker. Forum started by 3guptaanurag
9216
Standard weight of iron grill per feet
Last answer on 8/25/2014 8:17:34 PM. by JAI PRAKASH. Forum started by paresh
2130
Last answer on 1/16/2022 11:07:26 PM. Forum started by Aly Atif
1772
i want to fix up extra security grills for main door? main door is at-south-west
Last answer on 8/3/2012 11:25:14 PM. by P. Panchal. Forum started by sandhya
2061
Small Bathroom Ideas or Tips
Last answer on 1/27/2022 7:01:08 AM. by S L Gupta (Civil Engg). Forum started by rammohan.g
1829
can I built a small balcony for drying clothes @ N-W (Vayu Moolay)
Last answer on 7/3/2020 10:36:57 PM. by S L Gupta (Civil Engg). Forum started by vijay
1945
best material for external grills ,staircase
Last answer on 8/29/2014 2:08:35 AM. by JAI PRAKASH. Forum started by ADINATH
2185
2715
Balcony flooring
Last answer on 7/11/2020 8:10:08 PM. by S L Gupta (Civil Engg). Forum started by sdk
2122
Hi! I have shortlisted two flats 1. having main door in south direction, west op
Last answer on 3/21/2011 8:30:30 AM. by sabina vanjani. Forum started by Vasu
3216
for a flat
Last answer on 10/13/2010 5:18:56 PM. by lokareddy. Forum started by shrawan
3031
Last answer on 2/21/2022 6:45:23 AM. by S L Gupta (Civil Engg). Forum started by parkash
1775
kindly make the ghar nakash 30 gaj fournt(East side open) and 18 gaj deep(North
Last answer on 5/3/2016 12:14:03 AM. by JAI PRAKASH. Forum started by BHUPENDER RAJPUT
3652
18383
2962
1992
what is best for balcony iron railing or steel railing and why?
Last answer on 4/21/2015 11:30:50 AM. by S L Gupta (Civil Engg). Forum started by ashok
1521
i WOULD LIKE TO COVER 2ND floor BALCONY WITH ROOF AND CEILING.IS THERE ANY BODY
Last answer on 7/9/2016 2:06:00 PM. by S L Gupta (Civil Engg). Forum started by ramachandra
23
27
Balcony
Balcony is an extended platform that projects from a wall(interior or exterior) of a building, supported by columns an..
Precautions
What are various designs of grills in windows?
Window Grills are required for the safety of homes. Window glasses should be well covered with grills. Here are variou..
Home Security Grills and Their Fabrication
Good quality security grilles can ensure safety and protect home from burglars and intruders. Nicely fabricated windo..
Precautions
Precautions during Fabrication and Fixing of Window Grill.
Any small carelessness during fabrication works can deform the shape of steel doors and windows etc. Fabrication shoul..
Which are various types of grills for home ?
Aluminum grills have high tensile strength.
Basic
Basic home security tips
Porch
Porch Designs
Design
Design your Office
