Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> Ground floor in house without columns in middle
Sun Aug 16, 2015Total posts : 4
jaydeep
jaydeep
Topic: Ground floor in house without columns in middle
sir
i  am starting building construction  of ground + 2 floors  48*26( 1248 sft) & hight will be 12’ of each floor, at Kharagpur West Bengal, soil of here is rocky soil. I don’t want to put any pillar middle of construction as I want to use as parking area. need to know the following
1) What will be  footing depth & width
2) How many  piller require & what will be the size
3) How many  beam require & what will be the size
3) What type of  steel rod usage in piller & beam & roof
4) rule for plinth beam
5) What roof thickness required
Sun Aug 16, 2015Post  #1
Please check with an Architect or an Structure engineer in your area.
Mon Aug 17, 2015Post  #2
jaydeep
jaydeep
Post subject: Ground floor in house without columns in middle
Gupta sir i am waiting for your answer & Mr jai i post for answer not this type of  suggestion.
Mon Aug 17, 2015Post  #3
OK
Mon Aug 17, 2015Post  #4
Dear Jai deep
      You are constructing 3 story house. With out plan of the building and loading , it is not possible to tell the design. You should contact support@gharexpert.com wit plan of the building for design.
5124
3013
10312
900 Sqft column required
Last answer on 7/21/2021 11:11:14 AM. by S L Gupta (Civil Engg). Forum started by Shivaraj
3941
1191
I have an area of 1944sq feet in this I want graden and three floors house gron
Last answer on 4/23/2018 11:19:21 PM. by S L Gupta (Civil Engg). Forum started by Dilip Teja .G
3624
Wall unit
1366
1654
Respected sir, Please upload 29×66 south facing plot ground floor d
Last answer on 2/12/2022 12:31:01 AM. by S L Gupta (Civil Engg). Forum started by Vikram parihar
2573
3303
1879
Rework required on blinth beam.
Last answer on 10/1/2013 10:53:53 AM. by S L Gupta (Civil Engg). Forum started by ananth
1311
9555
Last answer on 10/17/2016 1:19:41 PM. by Vishal Thakur. Forum started by Vishal Thakur
2066
We have a Ground floor house already constructed some 15 years ago,and 2 floors
Last answer on 8/22/2013 10:36:36 AM. by S L Gupta (Civil Engg). Forum started by feroz khan patthan
2610
3642
I want to built a house with stilt,ground floor
Last answer on 8/30/2021 6:11:55 AM. by S L Gupta (Civil Engg). Forum started by venkatesha
2481
plan a corner house ground floor size 30'x50', south
Last answer on 1/19/2011 4:55:47 PM. by sabina vanjani. Forum started by bharat
15610
5811
3793
9885
2670
4628
4143
2865
5008
3657
1865
2801
2610
2373
2462
2638
1807
3608
6254
What are various types of panel doors?
Single panel, Double Panel, Three Panel, Six Panel doors........
Preliminary
Pool Pumps
Painting
Environmentally
