Drainage , Sanitary System and Plumbing
Wed Feb 18, 2015
ramesh
Topic: Guideline for Labor laying stoneware or SW Pipes
my G+1 floor house is under construction the contractor has lay 6 inch under ground pvc pipe below the foundation beam by just digging trench and after laying he just filled with murum and bolder. Is is coorect ? because other place I saw they dig the trench put cement and churi pcc below and also over the pipe after that they filled the trench with murum. Weather it may create any pro blame in future the way my contractor. your early replay shall be very help full for me. Thanks and Regards Ramesh Gandhe
The comment above talks about the article
"Guideline for Labor laying stoneware or SW Pipes"
Thu Feb 19, 2015
Dear Ramesh
The correct method is to lay concrete under pipe and than top of pipe be covered with Concrete so that if load come it will not effect the pipe of sewer.
2266
Last answer on 5/26/2012 8:18:55 AM. by
hafiz
1826
Last answer on 7/18/2016 11:26:37 AM. by
1524
Last answer on 10/3/2017 7:03:56 AM. by
gautam kumar
gautam kumar
4836
Last answer on 7/9/2020 10:10:27 PM. by
jptallam
2201
labour factor guideline
Last answer on 8/8/2011 7:14:57 AM. by
Rajagopal
2163
Last answer on 7/26/2010 11:21:34 PM. by
jyothi Kurup
1755
Last answer on 4/22/2016 11:37:09 AM. by
jameel5
1878
in as house well was in SW..but a new BORE was taken in NE..will this compensate
Last answer on 3/25/2011 12:53:49 AM. by
D.Ramachandran
2850
Last answer on 7/10/2021 9:46:38 AM. by
Quovino
ajaywahi
1989
PLUMBING
Last answer on 6/8/2016 1:29:11 PM. by
Last answer on 10/5/2016 11:34:14 AM. by
arun
arun
2231
sewage pipes
Last answer on 1/8/2014 12:17:43 PM. by
Ahmed
rajesh
2470
Farm House
Last answer on 11/3/2011 6:42:17 AM. Forum started by
shadow
1837
my flat is on 3rd floor and is SW facingpl advise necessary corrective measures.
Last answer on 12/12/2011 7:39:57 AM. Forum started by
poornima
3646
if a school plot is cut from SW what is the remedy to rectify
Last answer on 7/3/2020 9:20:50 PM. by
anu
2269
I have septic tank in SW. What is remedies
Last answer on 1/2/2021 5:27:45 AM. by
Pavan
sunil
1948
Bathroom in SW corner
Last answer on 2/3/2021 11:53:25 PM. by
Amit Sharma
2282
Last answer on 1/25/2014 1:06:21 PM. by
prasad
9175
Last answer on 4/19/2010 4:03:39 PM. by
narender
1885
tap Connection
Last answer on 2/16/2022 8:46:00 AM. by
SACHIN
SACHIN
3628
sunken slab
Last answer on 1/5/2022 2:15:53 AM. by
amog
2508
How to hire a plumber
Last answer on 11/16/2021 12:10:20 PM. by
anand
3498
Last answer on 2/21/2021 8:33:40 AM. by
rameshkumar
rameshkumar
2321
Last answer on 7/4/2020 3:04:07 AM. by
Mohd
3861
flush toilet
Last answer on 7/3/2020 11:14:05 PM. by
pallubc2
1960
Last answer on 8/8/2016 2:21:56 PM. by
Balu Menon
4721
Cost estimation for sump tank
Last answer on 10/30/2014 12:29:29 PM. by
Jaya Prakash
2220
water supply
Last answer on 6/18/2014 11:46:36 AM. by
simran
2042
Underground Water storage
Last answer on 2/11/2014 6:07:51 PM. by
Ahmed
Ahmed
2231
sewage pipes
Ahmed
rajesh
2252
commode & flush type
Last answer on 12/31/2013 1:52:12 PM. by
rajesh
rajesh
1949
WC issue
Last answer on 12/12/2013 1:54:20 PM. by
aammiitt
5626
Over-Head water Tank
Last answer on 10/26/2013 5:57:55 PM. by
Vastu for septic tank
Last answer on 6/7/2013 11:16:40 AM. by
Last answer on 5/14/2013 1:58:48 PM. by
Naveed zaka
2474
Septic Tank Design
Last answer on 4/30/2013 3:22:27 PM. by
Jitender Suhag
Jitender Suhag
3387
Last answer on 12/12/2012 2:44:23 PM. by
clarasmithh001
shabbir ali
3754
position of septic tank
Last answer on 12/11/2012 3:42:26 PM. by
clarasmithh001
ani
Guideline for laying DPC
