Gupta sir,My G 1 house constructed having 12 columns of size 15x9 inches.8 no co
Wed Sep 05, 2018Total posts : 3
Santosh Reddy
Santosh Reddy
Topic: Gupta sir,My G 1 house constructed having 12 columns of size 15x9 inches.8 no co
Gupta sir,My G 1 house constructed having 12 columns of size 15x9 inches.8 no corner columns has 12x8mm tmt rods.4 center columns has 16mmx8 rods. Now im planning to construct 2
Wed Sep 05, 2018Post  #1
Santosh Reddy
Santosh Reddy
Post subject: Configation of TMT rods.
Gupta sir,
My G +1 house constructed having 12 columns of size 15x9 inches.
8 no of corner columns has 12x8mm tmt rods used.
4 no center columns has 16mmx8 rods.
Now im planning to construct 2 and 3rd floor
Please advise is the tmt rods configuration is correctly installed?
Thank you,
Santosh
Fri Sep 07, 2018Post  #2
        It is better to take help from any local structural engineer who can guide you after visiting the site and inspecting the foundation. From the above details it is not clear about foundation whether it is for two story building or for 4 story building.
Mon Sep 10, 2018Post  #3
        The design of column including size and M S Steel is designed by structural engineer after taking the load which is bear by the column. Please take help from any structural engineer.
Column placement for house
3510
1366
1604
Respected Sir,We are constructing a individual house at an area of approx 450sq
Last answer on 12/2/2016 11:53:14 AM. by S L Gupta (Civil Engg). Forum started by ranjeet
1531
Last answer on 12/2/2016 11:43:21 AM. by S L Gupta (Civil Engg). Forum started by ranjeet
2421
start construction Steel use
3795
4588
Reagarding Coulmn Pillar
Last answer on 9/29/2015 11:01:46 AM. by S L Gupta (Civil Engg). Forum started by Amit Kumar
65239
1475
Floor extension
Last answer on 11/1/2016 12:10:42 PM. by S L Gupta (Civil Engg). Forum started by meghraj
2244
4664
Regarding Beam
3134
6604
Column design
Last answer on 4/26/2021 6:12:46 PM. by S L Gupta (Civil Engg). Forum started by Rajaraman
4431
2144
About column and beam structure
Last answer on 1/4/2019 11:39:23 PM. by S L Gupta (Civil Engg). Forum started by Rana kachari
9002
2095
in concrete piller using more cement sand than20 mm jelly what is the result will be?
Last answer on 5/19/2015 9:17:17 PM. by JAI PRAKASH. Forum started by manja nayka k r
1617
I have open site of 30'*50' size. I want to construct an house having sitout din
Last answer on 4/4/2018 1:22:54 AM. by S L Gupta (Civil Engg). Forum started by appasaheb
17
Right size cupola
