Home -> Forums -> Construction -> Cement Plastering -> Gypsum Plaster Vs S/C Plaster
Tue May 26, 2015Total posts : 3
Tarun
Tarun
Topic: Gypsum Plaster Vs S/C Plaster
Dear Members,
We have been given a choice of selecting right plastering solution between:
A) Gyproc Plastering (from Saint Gobin)
B) Normal Sand and Cement Plastering followed by POP.
I will be pleased to know expert opinion which mode of plaster we should choose.
To give you a background, it's our residential property with an area of 250 Sq Yd; where we are constructing four floors with a stilt.
I tried looking on net, but I haven't come across with any technical research between two; however, few old citations have recommended Gypsum based plastering over S/C plaster.
Your recommendations and suggestions will be of great help.
With regards,
Tarun Jain
Wed May 27, 2015Post  #1
Go for option B) Normal Sand and Cement Plastering followed by POP.
A) Gyproc Plastering (from Saint Gobin) is used for commercial purpose where you require re-modeling after few years.
Wed May 27, 2015Post  #2
Tarun
Tarun
Thanks Jai!
Any other recommendation(s)/suggestion(s)/explanation(s) of great help.
With regards,
Tarun
Wed May 27, 2015Post  #3
Dear Trun
Advantage
  • Gypsum plaster is directly applied on brick, block or RCC, no separate finishing product required.
  • It requires no curing, therefore ready to paint.
  • Gypsum plaster saves time during construction and ensures timely possession of homes/ building.
  • Gypsum plaster expands slightly on setting and is not, therefore likely to cause cracking of surface.
  • On drying out it forms a sufficient dense surface to resist normal knocks.
  • Gypsum plaster is comparatively easy to spread and level.
  • Gypsum plasters have no appreciable chemical action on paint.
  • Gypsum plaster spread and finished to a minimum thickness increasing carpet area.
  • Gypsum plaster is perfectly lined, leveled, sharp corner and smooth surface.
  • Saving on electricity used for air conditioning as gypsum has very low thermal conductivity.
  • It is more durable and green material.
  • Gypsum plaster light in weight, therefore reduces the load on structure.
  • More cleanliness on site because it is bag packed product and no curing is required.
  • Disadvantages of Gypsum Plaster
    • Gypsum plaster is not suitable for exterior finish, as it can not be used in damp situations.
    • Gypsum plaster is more expensive than cement sand plaster but cost disadvantages should be weighed against the advantages and the fact that the labor cost is appreciably greater than that of materials in plastering.
    • Cement plaster add structurally strength to the wall but not in case of Gypsum plaster.
    2713
    Kids room ceiling designs
    2157
    2924
    4626
    time for paint and wall putty
    2780
    Plaster work
    2110
    Gypsum plastering
    Last answer on 7/3/2020 11:51:16 PM. by Purvi Panchal. Forum started by sanu kumar
    1961
    1408
    crack on wall plaster by gypsum
    Last answer on 11/22/2016 1:25:44 PM. by S L Gupta (Civil Engg). Forum started by Rizwan
    3311
    Last answer on 4/27/2010 9:56:03 PM. by raghuns1974. Forum started by Mohit
    2052
    Tiles Vs Plaster on outer wall
    Last answer on 4/14/2014 7:53:27 PM. by awdhesh. Forum started by awdhesh
    35210
    2203
    7004
    2693
    cement plastering
    1417
    where are use in 20mm plaster
    Last answer on 10/22/2016 11:07:01 AM. by S L Gupta (Civil Engg). Forum started by Babasaheb Gite
    8879
    3992
    2413
    COSTING AND STRENGTH OF WALL
    5185
    Can the "Gypsum Stucco Plaster" be used directly on an unplastered wall??
    Last answer on 3/25/2011 1:57:52 PM. by Nikita. Forum started by Amogh Desai
    2929
    Plaster
    2780
    Plaster work
    3047
    Plastering
    1925
    2004
    PPC and OPC cement
    11298
    1871
    suggest for exterior
    7004
    9157
    1876
    OPC and PPC cement
    2157
    2012
    coarse aggregate
    1826
    Nice
    2173
    Outer Plaster
    2996
    2735
    putty work on walls
    2236
    2827
    2033
    Gypsum
    Checklist for Cement Plaster
    Specification of ‘Plastering’
    How to clean plaster ceiling?
    Plastering
    Plastering
    Ceiling
