Home -> Forums -> Construction -> Start Construction -> Gypsum plastering
Gypsum plastering
Sun Feb 15, 2015Total posts : 4
sanu kumar
sanu kumar
Topic: Gypsum plastering
     Please let me know whether gypsum plastering is better in terms of strength and durability.  Whether it can be replaced with cement sand plastering (both interior and exterior) and if so, can we reduce the cost of construction. If it is used for exterior plastering, does it cause any adverse effect on the exterior quality of house in long terms.
Sun Feb 15, 2015Post  #1
Its not so good at any place. It just takes lesser time and cheap. Thats it.
Fri Feb 20, 2015Post  #2
paramarsh
paramarsh
Stucco I believe is a much better alternative - made primarily of lime, sand and water. Looks similar and is cheaper that Portland concrete. Not sure what it might be called in India. Hope this helps. Try searching google images with these words:
"stucco wall exterior"
Fri Feb 20, 2015Post  #3
Dear Kumar
Benefits to builders / developers:for gypsum plaster
1. Green material
2. Shrinkage crack free surfaces - smooth finish
3. High productivity – faster work (Reducing plastering time by 70% when compared to conventional Sand cement plaster + POP method) so time saving
4. Performance – Durability, light weight (Reduces dead load on structure)
5. Cleaner sites - direct application bagged product – requires no water curing
Benefits to the end customer:
1. No shrinkage cracks on walls and ceilings
2. Reduction in the time required for plastering and this helps in timely possession of homes
3. Perfectly lined, leveled, smooth walls
4. Saving on electricity used for air conditioning as gypsum has very low thermal conductivity
Fri Feb 20, 2015Post  #4
Dear Sir Guptaji,
1. Do we need any surface preparation of brick wall for "Gypsum Plaster".
2. can we do it upon brickwork directly.
2437
Gypsum Plaster Vs S/C Plaster
1962
3311
Last answer on 4/27/2010 9:56:03 PM. by raghuns1974. Forum started by Mohit
2157
2713
Kids room ceiling designs
1408
crack on wall plaster by gypsum
Last answer on 11/22/2016 1:25:44 PM. by S L Gupta (Civil Engg). Forum started by Rizwan
1542
POP OR GYPSUM
5938
gypsum
Last answer on 1/14/2022 2:23:44 AM. by Antoni11. Forum started by shaju
2090
gypsum
Last answer on 2/6/2011 5:34:36 PM. Forum started by shaju
3009
2533
l would like to see more gypsum designs
Last answer on 1/14/2022 3:20:41 AM. by S L Gupta (Civil Engg). Forum started by salome kapanga
5185
Can the "Gypsum Stucco Plaster" be used directly on an unplastered wall??
Last answer on 3/25/2011 1:57:52 PM. by Nikita. Forum started by Amogh Desai
2924
2167
KINDLY TELL ME ABOUT DIMENTION OF FALL CEILING IN GYPSUM BORAD.
Last answer on 6/30/2012 11:31:21 AM. by Ar. Manoj Ralen. Forum started by Pawan Jain
2726
2945
i need to know more about how to design ceilings made out of gypsum material.
Last answer on 6/27/2021 4:32:10 AM. by Nisha Batra. Forum started by kagz ecma
3061
False Ceiling--POP or Gypsum, which is better?
Last answer on 4/28/2015 8:41:23 PM. by JAI PRAKASH. Forum started by ajaywahi
2184
Last answer on 5/5/2014 12:08:29 PM. by S L Gupta (Civil Engg). Forum started by ajaywahi
4626
time for paint and wall putty
3309
2133
2059
Gypsum
Ceiling
Checklist for Cement Plaster
Specification of ‘Plastering’
How to clean plaster ceiling?
Plastering
Plastering
