Home -> Forums -> Construction -> Steel -> HSD Steel Bars (High Strength Deformed Bars)
Sun Sep 15, 2013Total posts : 2
Tanmoy Mukherjee
Tanmoy Mukherjee
Topic: HSD Steel Bars (High Strength Deformed Bars)
I want BBS anchorage value plase send my email .
The comment above talks about the article   "HSD Steel Bars (High Strength Deformed Bars)"
Tue Sep 17, 2013Post  #1
The actual bond stress varies along the length of a bar anchored in a zone of tension, most international codes of specifications [2][3][4] use the concept of development length rather than bond stress. The main requirement for safety against bond failure is to provide a sufficient extension of the length of the bar beyond the point where the steel is required to develop its yield stress and this length must be at least equal to its development length. However, if the actual available length is inadequate for full development, special anchorages must be provided, such as cogs or hooks or mechanical end plates. The same concept applies to lap splice length mentioned in the codes where splices (overlapping) provided between two adjacent bars in order to maintain the required continuity of stress in the splice zone.
  Anchorage
in steel bars is normally provided in the form of bends and hooks; The anchorage value of bend of bar is taken as 4 times the diameter of bar
Sat Mar 15, 2014Post  #2
ijazulhaq
ijazulhaq
Post subject: HSD Steel Bars (High Strength Deformed Bars)
R/ Sir, How many 0.5 inch Dia" Mild Steel weight in 1 cft.
Steel-Construction Questions (39)
2905
RCC Roof
3063
steel formula
Last answer on 4/16/2014 8:05:15 PM. by shaik khaja nayab rasool. Forum started by shaik khaja nayab rasool
13798
overlap length to steel
1307
1638
3211
steel
13782
3112
1281
1533
1258
Is HYSD steel bars still used for construction. Do they meet the safety standard
Last answer on 1/10/2019 12:18:04 AM. by S L Gupta (Civil Engg). Forum started by rinu
1179
2039
2712
2306
2039
2963
Need help for terrace room to cover iron bars (Picture Attached)
Last answer on 12/28/2012 11:27:53 AM. by S L Gupta (Civil Engg). Forum started by prabhjeet
3913
construction of 1st floor
2616
2692
steel requirment
15615
1996
Residential complex
4373
RCC Columns
3243
7489
Bar Bending Schedule Software
2527
steel
29965
2616
9369
2290
Current iron rod price
2613
1892
Steel Erectors
2391
3275
13798
2164
2541
HSD
Type
TMT
Dining
Dining Chairs and Bar Stools
Precautions
