Hair line cracks in the ceiling on new 6 month old house
Fri Jul 06, 2012Total posts : 7
sanjeev kumar
sanjeev kumar
Topic: Hair line cracks in the ceiling on new 6 month old house
I constructed a house in which the RCC lintel(roof) was done in Jan 2012.
I am observing hairline crack in each room across the half centre of the roof.
The size of one room is 10x10 feet, other is 12x10 and 5x10 feet. The thickness of the lintel is 7 inch. After the lintel was done, I got the roof convered with plastic after 4 months to prevent water to get in contact with the roof.  On the plastice I put mud with 8 inch thickness to act as heat insulater. I covered the m ud with tile bricks of 1.5 inch thickness and closed the voids with a cement and rough aggerate mix.
It this due to tempeature variation or is it due the the load above. What should I do immediately and what is the cause because I have never observed anywhere else. Should I remove the bricks and mud above the roof to reduce the load on the ceiling. Shoud I also remove the plastic below the mud to let the roof breathe. Is the polythene harming in any way/causing the crack in the house. The house is in Delhi and all the perifery of the room roof has 9X12 inch beams.
Please reply, I will be very grateful.
Will the cracks spread all over the roof as now it is only in the centre.
Fri Jul 06, 2012Post  #1
sanjeev kumar
sanjeev kumar
Post subject: Hair line cracks in the ceiling on new 6 month o...
I can only see the crack in ceiling from below and do not know if it is on the floor of the roof as the roof is covered with polythene, wood and 1.5 inch thick bricks. Also, 10 mm rods were used across the lenght and width with 6'' spacing.
Fri Jul 06, 2012Post  #2
ravi seth
ravi seth
You must have put plastic conduits in the roof for electric wiring which must be going to the center where fan hook is.These cracks occur mostly at the bottom of the conduit when plastic conduit is not covered with wire mesh to improve its biding with concrete.Since these cracks are only limited to the bottom of plastic conduit it is not a worrisome issue but it does creates panic.Just next time when you repaint the house get these cracks filled with cement putty.
If you want to have a permanent solution , then  get scratched the underside roof where the cracks appear till the bottom of that conduit  say 2" -3" wide and depth till  the bottom of conduit is., put a strip of chicken wire mesh and repair the same with cement putty and paint.Remember to use 1:6 cement : sand mix than a rich mix, otherwise you may get cracks again.... which then won't be due to plastic conduit but hair line cracks due to different expansion coefficient  of a rich mix than used in the concrete above.
Mon Jul 09, 2012Post  #3
Dear Sanjeev
         I agree with Sh Ravi seth that this crack is under the plastic pipe laid for electricity wires.The other cause may be  that use excessive fine sand cause cracks in the RCC, it may due to not giving proper cover under cement concrete. As you stated the thickness of slab is 7'' than your RCC may be under reinforcemet etc. Please watch the crack for some time and if it not widened than it is OK and repair it as suggested by Sh Ravi Seth or visit the website gharexpert construction section       here the article about cracks and their remedy is given.
Fri Jul 20, 2012Post  #4
sam_m400
sam_m400
Sir
 What is this wire mesh you are talking about? I have seen construction where electrical guy passes these conduits under the rods without any covering passing it to different rooms.
what precaution we should take asking the electrician while doing the conduit where barbenders are laying the rods across for the roof?
Sam
Sat Jul 21, 2012Post  #5
Dear Sam
     Do not place the conduits under the MS steel bars. First complete the bar binding and than on the bars lay conduit.In this process you have not cracks stated by sh Sanjeev and there is no fear of breakage in the pipe during laying of salb by walking of labor.
Sat Jul 21, 2012Post  #6
sam_m400
sam_m400
Sir
In the mail he states "These cracks occur mostly at the bottom of the conduit when plastic conduit is not covered with wire mesh to improve its biding with concrete" . What does it means?
 Your recommendation is that  Do not place the conduits under the MS steel bars, so do we need to put conduit parallel to Stell bars or above it ?
do we need to tie the conduit along with the steel bars?
If it is above then there is chance that they will broken when somebody stamps while laying the concrete , but toeing along in parallel is good as it won't  broken. which is best option?
Sam
Mon Jul 23, 2012Post  #7
Dear Sam
If you put conduit under steel than the chances of breakage are more. lay conduit on the ms steel bars and tie them with steel bars.
New Home
2710
constraction details
Last answer on 1/1/2021 2:45:02 AM. by S L Gupta (Civil Engg). Forum started by ranvir kumar singh
3436
sunmica
Last answer on 12/6/2012 10:52:25 PM. by shailesh kumar singh. Forum started by tanaji
2298
can start a new building in adi month ?
Last answer on 10/5/2021 8:35:49 AM. Forum started by senthilvel
1693
i have constructed a new house. in all bed rooms where all pipes are laid in roo
Last answer on 7/23/2014 12:29:59 PM. by jitendra. Forum started by jitendra
2059
Cracks in my new house
971
My hair is falling out. How to stop it and grow it back quickly?For several mont
Last answer on 12/24/2021 11:15:32 PM. by TommyUno. Forum started by olii fill
7482
My hair is falling outHow to stop it and grow it back quickly?For several months
Last answer on 12/6/2021 5:35:21 AM. by Sunchez721. Forum started by olii fill
2125
CRACK IN CENTRE OF SLAB
3503
9894
3470
paint
3318
Last answer on 5/1/2012 11:09:41 AM. by S L Gupta (Civil Engg). Forum started by pankaj sharma
2706
How to fix cracks in my home
Last answer on 7/3/2012 12:04:18 AM. by Swati Satija. Forum started by vivek
3347
best ceiling LED LIGHTS FOR NEW HOME IN HARYANA CONSIDERATION VOLTAGE FLUCTUATIO
Last answer on 7/4/2020 3:58:43 AM. by Sushant. Forum started by sanjeev tiwari
2603
Using old bricks for construction
Last answer on 11/3/2011 11:02:20 PM. by susandixon. Forum started by Col MP Singh
1709
Crack in pop ceiling
Last answer on 10/20/2016 12:33:55 PM. by S L Gupta (Civil Engg). Forum started by Rizwan
1409
Today has just finised 15 days after intering in my new flat i recently come out
Last answer on 10/20/2016 12:10:03 PM. by S L Gupta (Civil Engg). Forum started by Rizwan
24
28
How To Repair Cracks
Surface
How to Paint Old Furniture
General
Ceiling
Happy
Happy New Year 2009
Dining
Dining Room Ceiling
Happy
