Home -> Forums -> Construction -> Cement Plastering -> Hairline cracks in walls and at 4" wall and pillar junction
Fri May 16, 2014Total posts : 1
sanjeev kumar
sanjeev kumar
Topic: Hairline cracks in walls and at 4" wall and pillar junction
I constructed a house two years ago in 540 square feet area. The  house has only ground floor now. There are eleven 9inch by 9inch pillars. All the walls are 4 inches.
I am observing that hairline cracks are appearing here and there in the plaster.
Please let me know why does it happen and how can I prevent it. Also, what precaution should I take while repairing it so that it does not occur again. With which material should I fill the cracks so that the cracks do not appear again.
Also, cracks which are a bit thicker than hairline are appearing at the meeting point of 4"walls and pillars. Why does this happen and how can this be
prevented because I do not want this  to happen if I construct the first floor. I first erected the walls and then casted the pillars.
Please help as Ghar expert is the only forum that gives the correct and accurate advise.
Attachments: 20140516_081442.jpg on Fri May 16, 2014,
20140516_081454.jpg on Fri May 16, 2014,
20140516_081718.jpg on Fri May 16, 2014,&n
Mon May 19, 2014Post  #1
Dear Kumar
Cracks must be repaired immediately when observed otherwise the life of structure will reduce causing structural failure. They not only weaken the building but spoil the beauty of walls also. The link below  tells you about repair of cracks in plaster, RCC member, Brick walls, Floor and Fine Cracks.
The cracks can be prevented at the time of construction. To know more about prevention of cracks during construction, click at the link below.
In your particular case I am in view that There is settlement in 4.5'' thick wall and crack with pillar is due to two different components having different elastic properties such as RCCpillar and brick work abating each other, the crack on face of plaster is formed between these components due to their thermal expansion. If read the link thriughly than find solution.
http://www.gharexpert.com/articles/Cracks-1468/How-To-Repair-Cracks_0.aspx
http://www.gharexpert.com/articles/Cracks-718/Which-Various-Reasons-Cracks-in-Buildings-_0.aspx
2362
dampness in corners at the junction of walls and floors
Last answer on 3/9/2011 12:14:27 PM. by Nenni. Forum started by AN CHORDIA
2729
2710
2338
1906
Last answer on 5/21/2013 8:56:40 AM. Forum started by Aji
White stains in the walls and cracks in the walls
Last answer on 2/23/2011 9:05:33 PM. by Muralidhar. Forum started by Muralidhar
2897
4137
2524
3380
Recurring Cracks
9195
2674
Last answer on 1/10/2022 11:40:17 PM. by seema tyagi. Forum started by vaishali
2697
Last answer on 2/20/2014 11:14:47 AM. by S L Gupta (Civil Engg). Forum started by HM12345
2580
Looking for Precast Engineers, Precast Compound Wall and Precast Slabs
Last answer on 5/12/2014 12:54:32 PM. by S L Gupta (Civil Engg). Forum started by nell
2924
3133
2351
2388
2929
Plaster
2780
Plaster work
3047
Plastering
1925
2004
PPC and OPC cement
11298
1871
suggest for exterior
7005
9157
1877
OPC and PPC cement
2157
2012
coarse aggregate
1826
Nice
2437
Gypsum Plaster Vs S/C Plaster
2174
Outer Plaster
2735
putty work on walls
2236
2827
2033
Brick Pillar
Canvas
Canvas Wall Art
How To Repair Cracks
Wall
Wall Decor
