Have a query.I am building a small house in Bangalore. I am planning to do a bri
Mon Jul 06, 2015Total posts : 3
Radha
Radha
Topic: Have a query.I am building a small house in Bangalore. I am planning to do a bri
Have a query.I am building a small house in Bangalore. I am planning to do a brick cladding for the house - does it matter if masonry is with bricks or cement blocks. Mainly from keeping the house cool perspective I want to know.
Tue Jul 07, 2015Post  #1
Go for red bricks.
Tue Jul 07, 2015Post  #2
Dear Radha
        See the below contents if fit than use
Thermal Insulation of Exposed Walls
The heat and cold radiate through exposed walls of the house. There are following methods of thermal insulation of exposed walls.
1. You may provide suitable thickness of wall.
2. You may provide Hallow wall or cavity wall.
3. You may fix Hardboards or ply board on wooden batten over the wall for creating air space.
4. You may fix Thermal insulating material sheet inside and outside exposed wall to reduce heat/cold transmission.
5. You may construct outer wall with thermal insulating material if you have frame structural building or non-load bearing walls.
Wed Jul 08, 2015Post  #3
Radha
Radha
Post subject: Thanks for answers
Appreciate the help.  Since exterior is hallow bricks (similar to total environment projects)  I am considering cement block masonry as opposed to brick as I am told no diff to inside house temp
Radha
1780
6147
1941
Hi, I am planning to build a home in Guruvayoor a small town in Thrissur Distric
Last answer on 11/18/2013 1:14:59 PM. by S L Gupta (Civil Engg). Forum started by jka0873
8190
Last answer on 7/3/2020 9:42:30 PM. by Beenu Phogat. Forum started by Prabhakar
1765
Hi Ghar Experts... am am small town, we are planing construct a house in our sma
Last answer on 2/10/2015 10:12:27 AM. by seema tyagi. Forum started by rajkumar
4995
Input required on Basement parking
Last answer on 7/20/2012 4:07:42 PM. by S L Gupta (Civil Engg). Forum started by vinay
3463
1456
i m having a small polt of 60 ft from north to south and 30 ft from east to west
Last answer on 11/17/2015 9:07:29 PM. Forum started by Munna Thakur
1340
2660
Last answer on 2/24/2022 11:54:36 AM. by S L Gupta (Civil Engg). Forum started by KUMAR RISHABH GIRIRAJ
1334
1968
Dear All,I am planning to build house(25X30) in Mysore, can any one suggest engg
Last answer on 10/5/2015 6:55:47 PM. by JAI PRAKASH. Forum started by M K Prem Kumar
2878
3230
3474
1758
Is Basement allowed in 60*40 site
Last answer on 4/2/2016 11:40:07 AM. by S L Gupta (Civil Engg). Forum started by Surya
1779
sir.iam in tamilnadu.we started to plan build new house in 900 sq.ft.i need some
Last answer on 7/27/2016 2:34:54 PM. by Beenu Phogat. Forum started by madhu
1078
I am about to construct my house..Would like to know that the plan I am sending
Last answer on 7/4/2020 2:46:48 AM. Forum started by SSHILPI
17
Cupola Proportions
Tips for cupola proportions
Orientation
Orientation of Building
Small
Small Space Kitchen
Tips for Small Space Bathroom
