Heat reduction in the top floors
Tue Mar 15, 2011Total posts : 3
Dr. Tiwari
Dr. Tiwari
Topic: Heat reduction in the top floors
Pls suggest me methods to reduce heat generation in the top floor of a three storied building. I live in a place which is very very hot and humid and AC is quite ineffective during the daytime ( where the summer temperatures can go up to 51 degrees and AC with more power is useless).I have read a lot about sun reflective paint,false ceilings etc etc.Can you suggest me effective solutions for this problem. Regards
Wed Mar 16, 2011Post  #1
Mohini Sharma
Mohini Sharma
Post subject: Heat Reduction in Homes.
Hello Dr. Tiwari,
Thermal insulation is a great solution to reduce the heat from outside to inside as it let the temperature remain same over weather changes. Thermal insulation can be done by two methods: Internal or External.
For more details click on the link given below:
Thanks & Regards:
Mohini Sharma
Tue Mar 22, 2011Post  #2
j smith
j smith
another way, is to have plants cover the roof area. In fact, there are ways to have direct plantings on the roof,  but if that is not possible, just have planters with green plants. this will not only reduce the heat, but will clean the air around your house.
Check out terrace or roof top garden articles which give you suggestions for how to do and what plants are feasible.
Wed Apr 20, 2011Post  #3
Rohan Jaacob
Rohan Jaacob
Hi Dr.Tiwari,
I can understand your problem, since I am facing it myself. I live on the top floor of my building and it gets really hot during the summer.We installed an air-conditioner recently, which is proving to be useless as you said.
I think the solution to our problem is Thermal Insulation. We need to somehow keep external heat out and make sure that internal cooling stays within the house.
False ceilings could be a good option. POP false celings are pretty common, but another option is Gypsum Ceiling Panels.
We could also gypsum plaster for finishing the internal walls. Gypsum offers very good thermal resistance and therefore gypsum plasters may help in reducing the amount of heat within the house.
You can find a lot of manufacturers of gypsum plaster in the market. A few of them are Star Gypsum, Shubham Plasters and Saint-Gobain Gyproc
Reasons of dampness
2232
1979
Last answer on 10/13/2016 11:06:46 AM. by S L Gupta (Civil Engg). Forum started by Saneto Fernandes
2237
How to avoid Heat in Top Floor
Last answer on 4/29/2014 11:15:27 AM. by S L Gupta (Civil Engg). Forum started by Aarif Eqbal
1982
Underfloor Heating - Home Heating Equipments
Last answer on 6/16/2015 4:05:32 AM. by JAI PRAKASH. Forum started by kevinlee
3910
2203
my house is on ist floor,but it gets too much heated due to terrace , what to do
Last answer on 10/2/2009 10:44:20 PM. by Priti Arora. Forum started by salim noorani
1191
I have an area of 1944sq feet in this I want graden and three floors house gron
Last answer on 4/23/2018 11:19:21 PM. by S L Gupta (Civil Engg). Forum started by Dilip Teja .G
1597
2400
what kind of roof heat resistent
Last answer on 2/11/2011 1:28:43 AM. by Nikita. Forum started by arun
1823
Which color tiles good for Heat
Last answer on 1/10/2016 8:51:34 PM. by JAI PRAKASH. Forum started by venkatesh
1966
Over Head Water Tank
3368
2419
Last answer on 10/18/2016 5:20:22 PM. Forum started by sandeepkelkar
2321
1961
inbuilt burner
Last answer on 7/4/2020 2:12:51 AM. by JAI PRAKASH. Forum started by ARVIND GOYAL
2273
Which Floor is better.. Top or Ground
Last answer on 6/15/2012 6:18:16 PM. by amit saini. Forum started by amit saini
3457
Last answer on 2/4/2022 11:19:50 PM. by Vaasku. Forum started by jayakrishnan
1989
Heat resistant
Last answer on 2/12/2011 4:01:14 PM. by Nikita. Forum started by arun
Kitchen Counter Tops Part-1
Kitchen design mistakes
Types of cupola
Let's find details about types of cupola in this writeup
What are various types of glasses used in windows?
Obscure glass provides you privacy allowing abundant light to the room.Tinted glass provides additional shading from d..
Pool heaters
Surface
