Home -> Forums -> Construction -> Layout and House Plans -> Height of ground floor & Cost
Fri Nov 02, 2012Total posts : 3
uma_vijayakumar
uma_vijayakumar
Topic: Height of ground floor & Cost
My plot size is 32.5x64 ft north facing. I am in  Coimbatore, TamilNadu. I am planning to build a house with complete ground floor for Parking. First floor with 3BHK house.
1) What should be the height of the ground floor.
2) I also want to know whether the cost will be same as when we build gound floor + first floor house or somewhat less than that, as I don't build anything in the ground floor.
Could anybody please advise me?
Uma
Fri Nov 02, 2012Post  #1
anand
anand
height under the beam should be 7'6" for parking..
parking flooring rate = 1/2 of first floor rate.
regards,
anand shah
Sat Nov 03, 2012Post  #2
Lokesh Dhiman
Lokesh Dhiman
the minimum height of Ground floor slab (T.O.C) should be 2500 mm (2.50m) to 3000 mm (depends on your local development authorities)
let me knw Permissible height of buildings in your area/sector..
and about cost, there is not much difference whether you build Ground floor or not, only Quantities of Materials and & some cost (Material & Labor)will be decrease : like-
Excavation work, PCC work
Brick work of foundations for Internal partitions walls
brick work of Superstructure (Internal),  Mortar, Plaster work,etc
as well as Lintels concrete, Steel & form work and time! :D
and  first floor cost, i dont knw abt indian prices of material n labor)
(may be 1000/- Sft to 1800Sft INR) not sure)) Ask to Local Qualified contracteur /Structural Engineer/Architects
have a Nice weekend
Tue Nov 06, 2012Post  #3
Alien
Alien
I also have similar problem with my own house. Its first floor is not high at a reasonable range, just at 10 feet which look like so low. Have it is good or not.
1283
HAI, MY BUILDING GROUND FLOOR HEIGHT 11.25FTS
Last answer on 7/4/2020 4:24:16 AM. by S L Gupta (Civil Engg). Forum started by VASUDEVA KUMAR
1492
2256
Pillar construction
Last answer on 8/17/2013 11:06:12 AM. by S L Gupta (Civil Engg). Forum started by SCK
1591
i want to knw cost about making a piller height 4 feet and 8*8
Last answer on 6/9/2021 8:12:51 AM. by ]Greis. Forum started by RUPESH RATHORE
1611
How much Marole required
5108
2581
COST construction of only 1 story house and construction of G+4 residential cost is 1:5 or different
Last answer on 12/8/2014 8:24:49 AM. Forum started by azad
3356
1779
2072
2492
2257
FRENCH DOOR IN GROUND FLOOR
Last answer on 2/11/2021 6:14:14 AM. by JAI PRAKASH. Forum started by sairam
1675
Cement requirement
1882
6267
4910
How much it cost for laying a foundation for a 30x40 site upto 7ft deep and plin
Last answer on 5/4/2013 2:20:44 PM. by nithun. Forum started by nithun
2697
2930
2194
2194
2809
4531
1898
2292
2278
2779
3474
2364
1980
2254
3602
2099
2801
1558
2128
Preliminary
Pool Pumps
Fountain Types
Terrazzo
Vastu for Water Tank
Swimming
