Hello all,I follow you for improving my knowledge. I want help in columns size o
Fri Jul 28, 2017Total posts : 1
poojathakraan
poojathakraan
Topic: Hello all,I follow you for improving my knowledge. I want help in columns size o
Hello all,I follow you for improving my knowledge. I want help in columns size of 15 feet x 60 feet house. It is 4 floor building.Columns size we have taken 9"x12". I know i should contact to structural designer for this. But since it is small house. Hope you can help me on this.Best regards,
Fri Jul 28, 2017Post  #1
poojathakraan
poojathakraan
Here is attached layout
Attachments: Working Drawings-Model_01.jpg Fri Jul 28, 2017,&n
750 Sqft Construction
2439
HOUSE MAP
Last answer on 7/4/2020 3:03:52 AM. by Lingraj Halli. Forum started by chhaganmodi
3795
4701
wants detailing of modilar kitchen size of otta 13' x 2' in l shape
Last answer on 2/21/2013 11:53:31 AM. by johnbritto. Forum started by vikas bahadure
5521
Triangular gaumukh and shermukh plot house plans
Last answer on 6/21/2016 1:00:40 AM. by Beenu Phogat. Forum started by Shaurya Rana
5026
600 SFT ACC 2BHK Costing
Last answer on 7/4/2020 4:20:53 AM. by JAI PRAKASH. Forum started by bharadwaj
615
Do you know what can help me improve my business? I'm thinking about developing
Last answer on 1/30/2022 2:40:31 AM. by SouthSidde. Forum started by HardissonHard
2702
2101
3017
6440
Column placement for house
857
Last answer on 1/27/2022 6:31:12 PM. Forum started by Rahul T Pal
9002
15781
2551
Advise on accommodating a staircase in existing structural plan
Last answer on 5/30/2021 11:00:09 PM. Forum started by Naveen Reddy
1937
hullo anyone that can help me out with taking off software links thanks
Last answer on 5/22/2014 6:46:37 PM. by kintu henry. Forum started by kintu henry
2586
flooring
Last answer on 5/31/2012 7:13:24 PM. by watson. Forum started by pallubc2
6548
6693
Need a design for My ceiling
Last answer on 2/24/2022 2:27:55 AM. by taroset. Forum started by amar
Right size cupola
What is binding wire
