Hello,I am planning to paint my house which is completed till plaster without an
Mon Jul 31, 2017Total posts : 1
Nirmal Bhowmick
Nirmal Bhowmick
Topic: Hello,I am planning to paint my house which is completed till plaster without an
Hello,I am planning to paint my house which is completed till plaster without any primer or colour.But there is problem, which is woryying me a lot.A exterior wall on the 2nd floor is soaking up water during the rainy season and as a result of this, the wall is absorbing water and the inside wall is getting moist.The mason who constructed the house recommended cement wash on the exterior as a solution for the damp.My query in this regard:1. Will it be effective??2. [MOST IMP]. after application of cement wash, will it be possible to apply paint on that surface, when I paint my house (approx 2years from now)???Will be a big help, if somebody helps me with the solution.Regards.Nirmal B.
Tue Aug 01, 2017Post  #1
         On newly plastered surface you may apply cement wash or priming coat/ apply cement primer of reputed  firm/ mark. After it you can paint the surface at any time.See below
Checklist for Painting Work
Before you start painting work
1. Fix scaffolding properly
Planks, bamboos and ‘Ballies’ don’t rest on or touch the surface to be painted. Proper stage scaffolding is erected for painting of ceiling. Double scaffolding is provided for exposed surface.
2. Fill surface voids, pores and cracks
All masonry or plaster surface voids, pores and cracks, nail holes are filled with filler before starting paint work.
3. Clean painting surface and room
The surface is thoroughly cleaned off mortar droppings, dust, grease and other foreign matters. Old work, all loose material and scales are removed by sand papering. The room is thoroughly clean/broom and the whole building is cleaned at least one day before painting.
4. Dry up priming coat for 48 hours
The priming coat applied already should be dried out for at least 48 hours before starting painting.
5. Fix electrical, water supply, sanitary pipes and door and window frames
All electrical fittings, water supply, sanitary pipes and door and window frames are fixed in required position and if found any short coming, it should be corrected and repaired before starting painting.
6. Wet the surface with water before applying cement paint
The surface is wet with water before applying cement paint. The surface of cement paint is cured (watered) after 24 hours of painting.
7. Employ skilled painter
The painter employed for painting is skilled enough to do the job well.
8. Allow newly plastered surface to mature for six months
Newly plastered surface should be allowed to mature for a period of at least six months prior to painting work. If you want to start painting before six months, a coat of alkali resistant priming paint should be done.
9. Fix ladders properly
Ladders used for painting work are tied with pieces of clothes on the top end of vertical members to avoid damage or scratches on painting surface.
While painting the surface/wall
10. Mix adequate distemper for one room
Enough distemper is mixed to finish/paint one room at a time. Color preparation for oil bond distemper is computerized.
11. Do painting in right weather condition
Paint work must not be done in adverse weather condition like hail storm and dust storm especially for exposed work. The paint work is not done in cold weather i.e. room temperature is not below 5 degree Celsius.
12. Stir paint well to maintain uniformity
The paint is stirred well in its original containers with the help of a solid wooden or iron stick during application of paint to maintain uniform consistency.
13. Do subsequent coats after 24 hours
Subsequent painting coat should be done at least 24 hours after the first is dried well.
14. Paint edges, corners, all doors and window accessories well
All edges, corners, top and bottom, bolts, nuts, sides, rebate, cleats, stops, bidding and sash putty with glass pan are painted well. There is no damage to furniture and fixtures during paint job.  At the time of spray painting, cover doors, windows, bushes etc.
15. Utilize proper brushes
The brush should be of 15 cm long, double bristles for wall paint. After each day’s work brushes are washed in hot water thoroughly with soap solution or with thinner and hung down to dry. Clean containers in hot water with soap solution also.
16. Wear protective glasses and be safe
While painting over head, wear protective glasses to avoid the fall of paint in your eyes.
17. Avoid alcohol and smoking
The painter should not drink alcohol during painting work as toxic fumes from paint are dangerous for his health. While painting, do not smoke to avoid fire near painting area.
18. keep children away from painting area
Don’t allow children to enter painting area as some paints contain harmful toxic elements. They should be not allowed to spoil painting work, if so wash them thoroughly with soap and water.
19. Park your vehicle away from painting area to protect it from the fumes of paint.
Check after painting is over
20. No brush mark is left on surface
Any brush mark is not left on the surface after the paint is dry. To avoid splashes of paint on wall the paint should be done on ceiling prior to walls.
21. Clean paint drops thoroughly
Paint drops on floor, electric fittings, door and window fitting and glass panes are thoroughly cleaned with good quality paint remover. After cleaning paint drops there are no scratches on glass panes and fittings etc.
1654
3821
4013
Paint vs Wallpaper
2296
civil supervisors with experience and who is trust-worthy
Last answer on 7/11/2011 12:02:49 PM. by aizaz ahmad. Forum started by Solomon
2455
2602
Basics to be followed while planning a residential house
Last answer on 5/31/2013 11:34:19 AM. by S L Gupta (Civil Engg). Forum started by girija
4809
Last answer on 6/29/2009 12:59:57 PM. by ningappa c k. Forum started by chinu
2237
Hello Sir,I am doing one interior project of a bank but some civil part I am fac
Last answer on 1/24/2022 9:12:12 PM. by JAI PRAKASH. Forum started by Gunjan
1061
I am about to construct my house..Would like to know that the plan I am sending
Last answer on 7/4/2020 2:46:48 AM. Forum started by SSHILPI
2764
Plaster work
2429
Supervisor/on-looker for house construction
Last answer on 2/2/2011 2:02:51 PM. by Abrar Ullah. Forum started by Solomon
6987
2588
Renovation of old house
Last answer on 5/24/2013 5:06:03 PM. by chandrakanth. Forum started by chandrakanth
2456
how to proceed with plan approval by the authorities
Last answer on 10/29/2012 4:09:00 PM. by S L Gupta (Civil Engg). Forum started by latha
1662
Last answer on 11/15/2016 11:30:27 AM. by Beenu Phogat. Forum started by Heeralal Chowdri
8150
Last answer on 7/3/2020 9:42:30 PM. by Beenu Phogat. Forum started by Prabhakar
4589
time for paint and wall putty
1466
hello,I am planning to renovate my house as per Vastu.plot is southeast facing,
Last answer on 3/5/2016 10:37:06 PM. by JAI PRAKASH. Forum started by Sheetal Jain
196
63
23
21
22
22
23
21
21
23
21
21
17
23
18
22
23
Checklist for Cement Plaster
Gypsum
Specification of ‘Plastering’
How to clean plaster ceiling?
Plastering
Plastering
