Home -> Forums -> Construction -> Start Construction -> Help regaring foundation
Wed Dec 29, 2010Total posts : 4
vaisakh
vaisakh
Topic: Help regaring foundation
Dear sir
.our land is stroing land.and my architect has given the foundation of 5 feet from ground level.is it necessary to dig 5 feet.we dig the land 3 feet to make the land plain and also dig 2 feet for the foundation.now the soil is rock hard.is i necessary to dig more.am ataching the foundation det below
Attachments: Foundation Details(sheet 2of2).pdf on Wed Dec 29, 2010,&n
Fri Dec 31, 2010Post  #1
Dear vaisakh
                  As position stated by you it is sufficient to dig 2'  foundation but care should be taken that the steps in foundation should be covered by filling the earth to raise floor level. In your drawing for outer wall if the side land is related to other owner than how you will accommodate the steps shown in the drawing of outer wall.
Fri Dec 31, 2010Post  #2
vaisakh
vaisakh
Dear sir
Thanks for the reply.i didnt understand the last point u mentioned.is this drawing fine ?
Sun Jun 12, 2011Post  #3
Anjan
Anjan
Post subject: Help - Foundation & Construction Cost
Hello,
I am planning to construct a house size about 2000 sq. feet in assam. I need help on selecting the kind of foundation, as my soil is soft.
Also, if you can guide about the cost of foundation, as my plan is to construct the house in three stage one by one.
1) Foundation
2) Roof
3) Wall and finishing.
regards,  Anjan
Wed Apr 16, 2014Post  #4
SANKARDAS BANERJEE
SANKARDAS BANERJEE
Post subject: DISCUSSION.
Dear Anjan,
You positively will engage a competent engineer to draw a plan for your proposed building who also will supervise the entire works during construction. 1st the said engineer will examine the soil strata and finally he draw the design of the foundation considering other concept and necessary. So I will advise you to finalize your plan with structural detail by engaging an approved engineer of your locality.
2430
Door Hinghes
Last answer on 12/28/2012 11:37:54 AM. by S L Gupta (Civil Engg). Forum started by Unnikrishnan
1890
Foundation Digging Help
Last answer on 1/25/2021 8:47:56 AM. by Shivaraj. Forum started by Shivaraj
1064
1890
2893
Foundation Brick estimate
Last answer on 7/4/2020 2:12:13 AM. by Bs Dhiman. Forum started by Bs Dhiman
4254
2321
2509
Pile Foundation
4949
3879
2420
2188
Last answer on 11/18/2013 10:57:21 AM. by S L Gupta (Civil Engg). Forum started by adari haripraveen
1918
Last answer on 11/18/2013 10:38:53 AM. by S L Gupta (Civil Engg). Forum started by adari haripraveen
6529
1701
material requirememt question
Last answer on 12/26/2015 7:41:53 PM. by JAI PRAKASH. Forum started by sushantsah
2068
Last answer on 4/6/2016 11:43:24 AM. by S L Gupta (Civil Engg). Forum started by zakia sultana
741
Hi sir,I have already make a foundation so I need
Last answer on 7/3/2020 10:30:07 PM. Forum started by Malik
1797
RCC foundation instead of brick foundation
Last answer on 9/23/2015 8:37:51 AM. by gpeter. Forum started by gpeter
3296
3309
2133
2059
Designing
Designing a Foundation
