Hi All,Is there any difference in strength of column, if we use 8 no of 12mm rod
Tue Aug 07, 2018Total posts : 1
vishal singh
vishal singh
Topic: Hi All,Is there any difference in strength of column, if we use 8 no of 12mm rod
Hi All,Is there any difference in strength of column, if we use 8 no of 12mm rods or combination of 6 no of 16mm
Mon Aug 20, 2018Post  #1
     If column size is 9''x 9'' or 9''x 12'' or 9''x 13.5'' the 6 nos 16 mm bar is better than  8 nos 12 mm bars.
Last answer on 8/20/2018 12:41:32 AM. by S L Gupta (Civil Engg). Forum started by vishal singh
1604
Respected Sir,We are constructing a individual house at an area of approx 450sq
Last answer on 12/2/2016 11:53:14 AM. by S L Gupta (Civil Engg). Forum started by ranjeet
1531
Last answer on 12/2/2016 11:43:21 AM. by S L Gupta (Civil Engg). Forum started by ranjeet
3899
For G 2 residential building, column size 9"*15",16mm 4rod,12mm 2rod used.. hori
Last answer on 7/4/2020 2:29:23 AM. by S L Gupta (Civil Engg). Forum started by Sathya
1979
Last answer on 10/13/2016 11:06:46 AM. by S L Gupta (Civil Engg). Forum started by Saneto Fernandes
3134
3795
2421
start construction Steel use
3608
1542
Cement Slab as roof for elevation
Last answer on 3/8/2017 12:01:54 AM. by S L Gupta (Civil Engg). Forum started by Neel
3030
2568
8651
6604
Column design
Last answer on 4/26/2021 6:12:46 PM. by S L Gupta (Civil Engg). Forum started by Rajaraman
2095
in concrete piller using more cement sand than20 mm jelly what is the result will be?
Last answer on 5/19/2015 9:17:17 PM. by JAI PRAKASH. Forum started by manja nayka k r
4650
2260
m15 cost vs m20 cost
2185
Bending the pillar rods on first floor
Last answer on 10/13/2016 11:16:31 AM. by S L Gupta (Civil Engg). Forum started by Saneto Fernandes
2419
surveying
Last answer on 5/27/2021 1:53:39 PM. by Bill Shiphr. Forum started by shaik khaja nayab rasool
Types of Cement
Compact
Compact Hi-Tech Kitchen
Hard
Skylight
