Hi ,I need to build compound wall for area of 12ft high and 40ft length 9 inches
Mon Nov 03, 2014Total posts : 1
Mahesh
Mahesh
Topic: Hi ,I need to build compound wall for area of 12ft high and 40ft length 9 inches
Hi ,I need to build compound wall for area of 12ft high and 40ft length 9 inches width with foundation . My contractor suggested this wall should be built with concert since this should prevent land side with 12 mm and 10 mm rod. He has coated Rs.150000 for complete construction including labor charges. I need advice from experts suggest me if this right quote and right type construction to prevent land side.
Mon Nov 03, 2014Post  #1
Dear Mahesh
           This can be under stand and calculated if plan and detail is available. I do not follow why land slide, this wall is in plain area are hill. What is meant by concert.
Compound wall construction
Last answer on 11/5/2014 9:02:10 PM. by SANJAY DUSANE. Forum started by Mahesh
6254
2855
Stair case
Last answer on 9/15/2021 12:40:33 AM. by Amit Hasija. Forum started by Hidayath
1682
Hi, two questions i have.1) my door lengths are 78.6 and 79 inches .Flush door s
Last answer on 2/8/2017 2:32:54 PM. by S L Gupta (Civil Engg). Forum started by Manish Chugh
1814
i have a 8marla plot length 64ft width 34 ft front street 40ft pls send me desi
Last answer on 4/18/2015 10:20:29 AM. by himanshu. Forum started by Rao Rafique Ahmad
2069
Last answer on 9/16/2014 11:09:41 PM. by bijumohang. Forum started by bijumohang
1502
1366
2943
RCC Roof SPAN
Last answer on 5/29/2013 10:29:12 AM. by S L Gupta (Civil Engg). Forum started by Rajesh
3119
concrete brick or clay brick
1703
35862
wall paint color combination
2032
Last answer on 1/28/2011 10:11:15 AM. by Nikita. Forum started by gururaj s sannakki
5555
2082
the land facing to east side, East - west 40ft and north to south 55ft. We need
Last answer on 8/14/2014 11:19:58 AM. by seema tyagi. Forum started by kumaresan
1181
1815
1543
Cement Slab as roof for elevation
Last answer on 3/8/2017 12:01:54 AM. by S L Gupta (Civil Engg). Forum started by Neel
4546
Construction of Compound wall
Last answer on 8/4/2011 1:22:22 PM. by S L Gupta (Civil Engg). Forum started by Sambasiva Rao Ravuri
23
27
Compact
Compact Hi-Tech Kitchen
Rugs
Rugs for Living Room
Orientation
Orientation of Building
HSD
What are various termite control methods?
INITIAL INSPECTION AND REPORT requires a complete thorough inspection of the buildings and surrounds, and a detailed w..
What
What is recommended size and shape of building for the protection in earthquake prone areas?
All parts of a building should firmly be tied together and stiffly braced at corners in such a manner that the whole s..
Canvas
Canvas Wall Art
